Panacea Deluxe Taillight
Anyone using the Panacea Deluxe taillight without using their stock turn signals? Looking for opinions from those that have them installed. Did you use in conjunction with your existing turn signals or by itself? Any concerns, if you removed your stock turn signals with seeing the turn markers within the Panacea taillight?
I'm leaning towards buying and installing, removing the stock turn signals to clean up the azz end. Thanks in advance for the inputs!
RE: Panacea Deluxe Taillight
You will be able to see the turn signals just fine but it won't be legal anymore if you remove your factory turn signals. The Panacea has the signals too close together in the eye of the law. Supposedly they need to be a certain distance apart. Not gonna lie it would clean the *** end up alot.
That is exactly what I did and as far as the law goes it completely depnds on your state, check this link for the rules for your state
http://www.amadirectlink.com/index.asp
Thanks for the inputs everyone. I'm going to check the heavycycles website once it is back up, but I am definitely pulling the trigger on something. Both Jake's and Cougar's bikes sold me. Plus, in VA, turn signals aren't required for inspection by law.
Thanks to all
Thanks to all
