what is that ticking noise?
Old 04-27-2008 | 04:11 PM
Delmarksman's Avatar
Delmarksman
Default RE: what is that ticking noise?
I hear a "tinking" sound. it's the keychain flapping in the wind.
It was driving me bonkers till I actually saw it flipping and heard the sound at the same time.
Old 04-27-2008 | 04:44 PM
2005UltraNC's Avatar
2005UltraNC
Top end on these things are normally a bit noisy. Need to isolate the ticking noise - is it top end or bottom end, etc.?
Old 04-27-2008 | 04:47 PM
2tonebob's Avatar
2tonebob
See if your headlight is loose, I had the same problem and it turned out the rivets that hold the light housing to the mounting bracket were a little loose. I drilled 2 of them out and used some short panhead screws and nuts with loctite and no more ticking!.
Old 04-27-2008 | 05:26 PM
Topspin's Avatar
Topspin
Mine sounds like my mother's old console Singer Sewing Machine did back in the 1970's.
She didn't pay $4.09 for Premium Unleaded like I did today. Dayyyyyumm.
Old 04-27-2008 | 05:54 PM
sargek's Avatar
sargek
Pretty sure my carbed 04 WG is ticking because of valvetrain noise - at least that's what I think...From what folks here say and from the thing not flying apart the past 2 years, I would think it's normal. It's definately top end noise though - bottom end noise is heavier and generally signals impending doom...
Old 04-27-2008 | 06:28 PM
wrobo13's Avatar
wrobo13
Nothing loose on my body flapping in the wind, or loose headlight or A/C, it'scoming from the left side of thebike. I think it's louder when the bike is cold and just started? I'm not too worried about it though. Like the tech said, if it stops making noise, then you have something to worry about.
Old 04-27-2008 | 06:39 PM
sargek's Avatar
sargek
Left side here too - top end, left side. WG doesn't use a key when running so I know it's not that...maybe it's my gremlin bell
Old 04-27-2008 | 07:19 PM
RAWHIDE07's Avatar
RAWHIDE07
I'm sitting in a quiet room right now and I hear a whining noise and strange voices and I'm sober!
Old 04-27-2008 | 07:50 PM
rbabos's Avatar
rbabos
It's probably the valve train, as in rocker end play you are hearing. Harmless noise.
Ron
Old 04-27-2008 | 09:58 PM
DougsDyna's Avatar
DougsDyna
Any or all the above. The injectors can be irritating on ocassion, too.
DougJ
Quick Reply: what is that ticking noise?
