Whats does everyone run for gas
RE: Whats does everyone run for gas
I do the same. Get the highest available where I stop. Say it's .22 more then reg and it takes 4 gallons to fill, that's a whole .86 (less then a buck) more to fill then using reg. and with getting a consistent 45 or more mpg's it's not that much more to give her the good stuff.
ORIGINAL: dynasty
we only have 91 here in So. Cal. that's what i use. the higher the octane, the better the gas.
So if we want explosive power is lower octane "the better the gas"?
What to do? If your at 9/1 you can run middle grade or swap every other tank. I like to top off with High Octane when I put it away for the winter because I'm gonna put some additive in it and it's gonna sit for a few months. Otherwise, LOW OC is fine, like my one buddy sais "It aint gonna be in there that long any way". Buying fuel from a reputable source is probably more important than what the OC rating is.
If you like giving B.P. an extra 20 cents per gallon every time you top of, go ahead. Its like paying a hooker an extra $20 causeSHE has an orgasim, what do you get out of it?
UNLESS!!! you have a custom bike with a higher compression ratio.
