stock street bob riser height
RE: stock street bob riser height
make your own if oyu only want an inch! they are liek 5 bucks to make with local parts form a hardware store... here is a pic of the ones i used to have on my bob... if you look below my stock risers those are the ones i made last time... all you need is some chrome pipe (the kind you put on plumbing under the sinks), some fender washers, hardened bolts,and chrome push caps... then just a bit of give it a go attitude!
[IMG]local://upfiles/26534/B2A1E9720BAA4DAB9B5CD32DC53EFD13.jpg[/IMG]
Stock risers are 2" on '07 St Bobs. I installed 3" domed risers that come with separate top clamps (one for each riser). Sort of a slight hour glass shape which is more pronounced in the same 5" domed risers. No problem using stock cables with the 3" risers, etc except you need to bend the brake line slightly (and carefully!). Got them off ebay from American Classic, but also available from J&P as well as others if you like spending more money for the same parts - LOL! Wanted an extra inch as well as separate top clamps so I could install a Baron tach on the handle bars between the risers (yet to be installed). When watching Ghost Rider, I noticed the same style risers on Nick Gage's chopper and knew i had to have them!
+1 My 07 SB Sock Risers were 2”.
4” risers with no cable change:
https://www.hdforums.com/m_3121987/tm.htm
3” risers:
https://www.hdforums.com/m_3099943/tm.htm
ORIGINAL: celtsfan
chipstah...where did you find those skulls for the tank console?
