Began dismantling my narrow glide this afternoon
#32
#34
Thanks for the positive comments everyone!
I bought a Heritage type fender on flea-bay a couple of days ago and it is actually in the mail (UPS) currently.
Also, I've found a set of tins (that cover the triple trees) and driving lamps/turn signal/"hammock" bracket that I plan to put on it. I am sure it will change the overall look pretty significantly.
A few people have actually seen it over the last couple of days and asked me which model it was, to which I've replied Super Glide. I've seen some pretty strange looks to that reply ... maybe I should tell them some made up name! You have a preference for Fat Glide or Super Boy? I've begun to think of it as a FLDI ....
R/
Priest
R/
Priest
#36
I also took delivery of the engine guard I ordered. It is slightly off on the measurements for a direct bolt on, but close enough that I already have a 'work around' figured out and should have it mounted by the weekend.
I think the passing lamp assembly will be here by Friday and think my fairing will be here, too. Not sure how long it'll take to get my lower fairings, but I don't think it'll be too much longer.
Within about a week or less, the front half of my bike should look pretty much like an Ultra Classic. I am thinking (expecting) my commute will be much more comfortable!
Now, this way I won't have to write one of those "sorry guys I bought a bagger so won't be hanging out on the Dyna forum" threads! [J/K]
R/
Priest
#37
New photos that show FLST triple trees
Took a couple photos today of the triple trees while I had the front end dismanted ....
One photo shows the 'tabs' fore and aft on the lower triple tree on which the 'cow bells' (also known as 'beer cans') are attached ... the other photo shows the threaded holes on the outer edges of the upper and lower triple trees where the fork tins themselves are attached ... two screws go on each side (one each top and bottom) ....
The QD windshield attachment is just longer screws with a hard rubber keeper for the upper and lower attachment points of the windshield bracket ... my fairing goes on the same way using the QD windshield hardware kit ....
R/
'Chop
R/
'Chop
#40
Here's a 'how to' thread I did on the floorboards ... https://www.hdforums.com/forum/dyna-...na-photos.html
THX for the props ... a number of guys have done the same front end transformation on '06 and later Dynas ...
You might check this 'social group' ... there's a lot of info there ... https://www.hdforums.com/forum/group...est-group.html
