Axle Nut
Axle Nut
I just finished removing my rear wheel.
In the process, I damaged the axle nut. I think I ever so slightly bent the thread in it, because I can't finger tighten it all the way onto the axle.
Anyway, I'm figuring I'll have to replace it. I'm assuming I can pick up a nut this size at an auto or hardware store.
Is there anything special I should look out for with the new nut?
This may sound like a stupid question, but I'm new and don't want to risk a failure. I'm guessing if a lug nut is good for a car/truck it'll hold up on the bike.
As always, any and all replies are welcome.
Thanks,
Ray.
Thanks,
Ray.
RE: Axle Nut
Ray,
get a new nut from HD. part # 8039. About 2 and a half bux.
You may not have a damaged nut or the threads on the axle.
Run it on with a socket and see if you notice extra resistance.
If so, get a new nut.
mud
mud
ORIGINAL: RazorFXDB
Thanks,
Ray.
Thanks,
Ray.
RE: Axle Nut
ORIGINAL: Sandcrab
Check the axle also. Maybe the nut is ok or was ok but the axle threads were nicked. If the axle threads are nicked, buying a new nut won't fix it. Get an inspection mirror and check it all the way around.
Thx for the reply.
DarkManC
03-05-2014 09:31 PM
