Rear Whel Help/Advice Needed
I have a 5.5" cast wheel I'm trying to mount on my 06 Wide Glide. The hub with the stock pulley installed measures 1/2" wider than the stock wheel. I assume I could cut the spacer down 1/2" and thr assembly would fit between the swingarms, but I would still be out of alignment with the front pulley.
I'm looking for advice here. Can I get a pulley that is 1/2" narrower? I'll ask the guy from whom I bought the wqheel if he has narrower hubs.
Any insight appreciated.
RE: Rear Whel Help/Advice Needed
Don't know if I can help ya out or not. But give me a little more info. What did the wheel come off of? Is it a stock Moco wheel or aftermarket and what size are the pulleys, yours and the one on the wheel? Yours is probably 1 1/4 or so. Anyways, we need more info to go on from this point.
Saint
Saint
Shrug
05-03-2008 01:37 PM
