Front pipes bluing...
Old 04-12-2008, 04:32 PM
Rocky11's Avatar
Rocky11
Rocky11 is offline
Default RE: Front pipes bluing...
Here is a pic of my Bonnie single wall pipes set up very lean from dealer.
all single wall pipes will blue unless tuned correctly BTW bonnie had only 850 miles on it.
Mark
Old 04-12-2008, 04:43 PM
Trotter's Avatar
Trotter
Trotter is offline
Air density .... Humidity ..... all goes along withJuly/Augustweather ........
ORIGINAL: flynavy
Yep ... makes no sence to me too spend all that money on a nice new bike and chrome **** instead of buying a good tuner and haveing it dialed in first ... If it's popping now wait till August...LOL
Why would infrequent popping now be worse come August? The setting on the tuner will not change...the pipes and a/c will not change....can you explain further?
Old 04-12-2008, 08:42 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,770 Likes on 2,533 Posts
I realize the difference between DFO's and PCIII's, but here's what I noticed on my 05 FXDLI. Prior to my DFO install I had blueing on front and rear header pipes. I removed the blueing (Blue Job), then installed the DFO and dialed it in just to to the point of no decel popping, that in turn made the fuel mix a little rich (just a tad) haven't had any blueing in 1500 miles. If you have the dealer dyno the bikes and set the mix, they are obligated by law to go back to EPA lean. Some might turn a blind eye to the requirement and some stick to the letter of the law. Fly Navy you may have to find some one to help you go a tad rich. Have you checked your plugs to see how they are burning? Good luck.
Old 04-13-2008, 09:54 AM
pinoy's Avatar
pinoy
pinoy is offline
Take a look at my pipes,i've a wideglide-07 stage 1,hav'nt dyne it yet.
[IMG]local://upfiles/56091/2793A562DAF041EA82958FAD57CA3B30.jpg[/IMG]
[IMG]local://upfiles/56091/207DB579005643F7AFEADF192407B300.jpg[/IMG]
[IMG]local://upfiles/56091/27F2AB83A570473C910E7ED884BF6227.jpg[/IMG]
[IMG]local://upfiles/56091/6B827D881EDF41E79FCF26DAD8CC635E.jpg[/IMG]
[IMG]local://upfiles/56091/8A5E749CCC744072A5B1FBEB230163FD.jpg[/IMG]
Old 04-13-2008, 09:57 AM
CSA's Avatar
CSA
CSA is offline
That is a nice ride Trotter! I love everything about it!
Old 04-13-2008, 10:49 AM
flynavy's Avatar
flynavy
flynavy is offline
Senior, What is a "DFO?" I have a Stage I with a V&H fuel pak. My bluing could be from the first 3K I put on the bike when it was stock. There is some gold mixed in toward the outlet of the head.
Old 04-13-2008, 12:57 PM
Trotter's Avatar
Trotter
Trotter is offline
Navy go out and ride the bike at night for about 20 min or so ..... Come home and let it sit and Idle for a3 or 4 min and look at your head pipes, up where they come out of the head and see if there glowing ....... Make sure it nice and dark and look under the heat sheilds.... You'll find your answer.... Mostly the rear...
Old 04-13-2008, 02:13 PM
flynavy's Avatar
flynavy
flynavy is offline
...ok Trot, and if it's "glowing" is that good or bad? rich or lean?
Old 04-13-2008, 04:41 PM
Trotter's Avatar
Trotter
Trotter is offline
Very Bad....Way too Lean ...... Thats whats causing the pipes too turn.. Add some fuel to theIdle circuit, If Vance and Hines will tell you How...Or if it's even possible with a fuel Pak ... I think they stay within EPA's guidelines so they can sell them Legally ..LOL .... You need to get it down from 14.7 to around 13.5... Good Luck ...Save some Money and buy a SERT have it tuned End of all problems, If you think itrun's good now You'll be very surprised.... After all you really don't have anything to compare it too if you haven't Installed a SERT and Had it tuned....Sometime you just have to trust some one that owns a Dyno Center and tunes Bikes for a Living.....Or just Keep guessing.....Whatif... Having the bike dialed in for Maxim Efficiencywill pay off in the Long run.. **** the HP and TQ numbers they mean nothing.... Unless you have built the Motor forjust performance purpose...
Old 04-13-2008, 05:28 PM
twofish's Avatar
twofish
twofish is offline
Quick Reply: Front pipes bluing...
