4 INCH PULLBACK RISER HOW TO INSTALL
JUST GOT HOME WITH 4 INCH BACK RISER. STEALER SEZ, AN TRIED TO SELL ME ALL NEW CABLES. HAS ANY ONE DONE THIS THAT CAN SHARE? IAM SURE OTHERS CAN GLEEN THE INFO AS WELL. THANKS A TON IN ADVANCE[sm=admin.gif]IVE LOOKED BACK THU THREADS FOR INFO, KNOW IT MUST BE THERE, BUT NO LUCK
1 Post
RE: 4 INCH PULLBACK RISER HOW TO INSTALL
I have a 06 Street Bob(not exactly the same model as yours, though), and I put on basically the same risers. Your cables and wires should be no problem. Your brake line may need a little tweaking(straightening). Just be very careful as you bend it. You may want to remove/re-locate the bracket that holds the line in place on you triple tree. It's not very difficult. You should be fine.
