can someone tell me what I'm doing wrong
RE: can someone tell me what I'm doing wrong
Low, I'm not sure you can link it to an image in the gallery. You should go to a free photo-hosting site like photobucket and upload your pix there and then paste the link to your signature. Be sure you use the [IMG] and [/IMG] tags, though, instead of the [img] and [/img] tags that photobucket will give you. You can edit them after you paste the link in. Also, be sure you close out of photobucket before you try to view your sig pic. For some reason, it won't display if you have the pic open in photobucket - probably because it is locked while open.
ORIGINAL: BLade1127
when you are viewing the picture in your gallery, click on it again. It will open it up in a new window. Copy that URL instead. You can use [img][/img] here.
Scott
