Foward control install on 07 Street Bob
As you all know the stock Street Bob comes with mid controls. The shifter shaft goes right through the primary cover. Is thereany way to get rid of the old shaft and lever without pulling the inner primary?
[IMG]local://upfiles/54217/16D3DEADBB1B49D38DCB4AEBC640C6F0.jpg[/IMG]
RE: Foward control install on 07 Street Bob
ORIGINAL: WS6 Formula
You don'thave to remove the primary on the 2006 and up Dyna's. The 2006 kit comes with a longer rear shift lever that requires you to remove the primary to install it. That longer shift lever will give you more leverage for an easier shift, but it will also increase your throw. I preferthe shorter throw andit isn't any harder to shift then the original set up. I bought thethe cheaper 2005 kit because I planned on getting a custom shift rod. You have to use a longer shift rod with the 2005 kit other wise the front shift lever will hit the primary when you up shift. Also the 2005 kit comes with a bracket to bolt down the original shift lever, but it is pretty easy to remove, read below.
Removing the original shift shaft lever
Geta hacksaw blade and tape each end with duct tape, leaving about two inches exposed in the middle. Also put some duct tape on the primary and cylinder cooling fins. Tape a wrench onone end to get a better grip (on the end of the bladeso as you pull on the wrench you will be on the cutting stroke of the blade). Slip the blade between the primary and engine from the bottom of the bike with the wrench end on the bottom. Use your other hand to guide the top of the blade as you cut. I cut about three quarters thru then wrapped a rag around the shift lever and used vise grips on the other end of the shaft splines and sheared it off.
Coverforthe original shift shaft lever hole
I used achrome carriage bolt http://www.chromebolt.com/51618-x-13...olt-p-845.html, and put atwo inchpiece of rubber hose on the threads then added some shrink sleeving on the hose to get a nice snug press fit into the empty shaft hole.
Forward control part numbers here:
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Shift Linkage part numbers here:
http://www.harley-davidson.com/brows...bmLocale=en_US
Check prices here:
https://www.zanottimotor.com/shopping/partLookUp.html
Forward controls and linkage on my 06 Low Rider
49080-03A Forward Control Kit (Fits '93-'05 Dyna models)
33815-06 Round Polished Stainless Steel Gear Shift Linkage (Fits '06-later FXDWG and Dyna models equipped with Forward Control Kit)
Check prices here:
