Are the Superglide double front brake wheels the same as single front brake wheels?
Old 04-02-2008 | 11:10 AM
Humanoid's Avatar
Humanoid
Default Are the Superglide double front brake wheels the same as single front brake wheels?
I have a 2005 FXDXI. I want to find some stock mag wheels and powder coat them black. Can I used mags off of any superglide or do I need to make sure they are the dual brake in the front? Basically, are all the superglide mag front wheels the same?
Thanks
Old 04-02-2008 | 01:46 PM
wkdavistx's Avatar
wkdavistx
Default RE: Are the Superglide double front brake wheels the same as single front brake wheels?
The wheel hub has to be drilled/tapped to accept a rotor. So, the answer is... you have to find a wheel that is for a dual disk setup.
Old 04-02-2008 | 02:10 PM
FastHarley's Avatar
FastHarley
Former Sponsor
As far as your question: "Can I used mags off of any superglide or do I need to make sure they are the dual brake in the front?"
The hub with is very important. You need to measure that. Their are various width hubs that have both taped and untaped hub faces. That does not mean all sizes fit everything.
Old 04-02-2008 | 02:32 PM
dyna07custom's Avatar
dyna07custom
ORIGINAL: wkdavistx
+1
Old 04-02-2008 | 04:52 PM
Humanoid's Avatar
Humanoid
Hmm ok. Thank you all. I will probubly have a hard time finding a used dual brake wheel but I will try waiting to see if one pops up on ebay.
The other option is to have my bike down for the time it takes to do the work and I dont like that idea much.
simple softail
EVO
04-09-2018 03:41 PM
Mattism78
Stock Harley Take Offs
02-20-2014 11:22 AM
Shepherdboy44
03-03-2013 06:00 PM
SalsaNChips
02-15-2011 08:15 AM
timberwolfz28
10-20-2008 12:18 AM
Quick Reply: Are the Superglide double front brake wheels the same as single front brake wheels?
