HD FOG LIGHTS
HD FOG LIGHTS
Anyone ever put the HD fog lights on there bike. Im thinking of putting them on my engine guard for 3 points of light. I know PIAA makes nice light, but there alot more expensive.
[IMG]local://upfiles/52091/65BAE80D1B6C4718BC07688AE00E689E.jpg[/IMG]
[IMG]local://upfiles/52091/22E0965FE89541C9A8B0D25A8C09DA5C.jpg[/IMG]
RE: HD FOG LIGHTS
I've had 'em on for about 4 years. Lights the road pretty darn good. I would do it again.
Just a side note:
When doing the install drill the engine guard where you place the lights and run the wires "inside" the engine guard. This makes a much cleaner install than just using the zip ties to stick 'em on the engine guards.
Things Learned:
The included relay is rated for 35 amp. Most Piaa replacement bulbsare 55 ampsand will pop the relay.
Just a side note:
Things Learned:
RE: HD FOG LIGHTS
Try this:
http://www.motolight.com/
I don't know if they make them to mount to your engine guard or not but they are well manufactured.
RE: HD FOG LIGHTS
I installed a set of these and they work great. $12 at Walmart . You have to do some creative wiring and I bought the Harley switch and mount for the handlebars but still a lot cheaper in the end. Also you can get some clamps at the dealer for mounting them where you want. I recommend to get the customer accessory pigtail for about $18 at the dealer so you can connect the power for the lights directly to the wiring harness- it runs off the mostly unused 15 amp customer accessory circuit fuse.
Mike Horrell
02-03-2010 02:56 PM
