Dynoe'd and tuned - Numbers
Old 03-29-2008 | 01:33 PM
AdrianVall's Avatar
AdrianVall
Default Dynoe'd and tuned - Numbers
Hey all,
Well, as some of you read, I got my bike dynoe'd and tuned this morning. It took him about 40 minutes in the morning, and when I went to take it for a ride, it was backfiring like whoa! Completely unnacceptable. I took it back, he tried again and same thing. Finally after the 3rd try, he got it right. Bike runs nice and he extended the rev limiter.
Here are my numbers: went from 64.13 HP to 66.66 HP
68.84 Torque to 70.04 Torque
This is on an 06 Dyna streetbob with 88 ci. motor, V&H Big Radius pipes, Arlen Ness Big sucker stage 1, and PCIII.
Do those numbers sound OK or what? I was very upset about having to take it back to him 3 different times, but it's good now.
Cheers,
Adrian
Old 03-29-2008 | 01:56 PM
Topspin's Avatar
Topspin
Default RE: Dynoe'd and tuned - Numbers
Adrian...
Sorry dude... mine went perfectly. Can't compare our numbers as I have 96".
After all the BS, is it running well now?
Old 03-29-2008 | 02:10 PM
PigInaBlanket's Avatar
PigInaBlanket
That sounds a little low on the numbers to me but I could be wrong. My old 883 Sporty with the basic 1250 conversion (pistons and cylinders replaced)was pulling 65hp and 70 tq. I figured the torque would be higher at least on yours.
Old 03-29-2008 | 02:32 PM
greenstreetbob's Avatar
greenstreetbob
For all the money spent, I'd be a little disappointed.
Old 03-29-2008 | 02:37 PM
jjwin98's Avatar
jjwin98
I have big radiuspipes and s/e hiflow a/c with the sert got 73 hp on dino
on a 06 Street Bob
Old 03-29-2008 | 03:02 PM
SUPER01's Avatar
SUPER01
I can tell you my 2001 FXD put out 69hp and 77tq. I am running AN Big Sucker, Yost Power Tube (I have a carb) and Cycle Shack slip-ons.
Every bike is slightly different, so if it is running good with no backfiring all is good.
Old 03-29-2008 | 03:29 PM
DougsDyna's Avatar
DougsDyna
With a TFI, K&N and drilled out pipes, I got 74HP/78TQ back in 06 on the Dyno. He didn't tune, I did by feel, sound and reading my plugs.
To note: every dyno is different andnumbers can vary greatly. I am curious as to why a tuner would ever give a customer back a bike that popped a little, let alone backfired.
DougJ
Old 03-29-2008 | 06:17 PM
AdrianVall's Avatar
AdrianVall
It runs pretty well now. Love that rev limiter extender. My RPM range has completely changed. Its awesome! But I did think that numbers did sound a bit low. And, I will rarely get a bit of backfiring, but thats only if I really try to get it to pop. Do you think I should take it back to him again and have him redo it, or what? I'm not entirely pleased with how it went down today but it seems to be running alright now. Should the backfiring be completely non-existent at this point or what?
Cheers,
Adrian
Old 03-29-2008 | 06:53 PM
strengthin1's Avatar
strengthin1
ORIGINAL: AdrianVall
You may find that you will have to go back a few times until he finds your sweet spot. Also it may start pooping more the hotter the bike gets. Be prepared to go back again.Kind of goes w/ these RT's. The numbers do seem a little low for the mods you've made.I've seen where different pipes on the same bike will move numbers around too. Some pipes look great but are robbing the bike of HP or Torque. You'll get there just don't settle for "good enough". Just my 2 cents and that's about all it's worth! Nice ride too.
Old 03-29-2008 | 07:02 PM
DougsDyna's Avatar
DougsDyna
Crackling, and popping under extreme riding are probably normal for any engine, but not backfiring.
DougJ
Quick Reply: Dynoe'd and tuned - Numbers
