what is the BEST oils for H-D
Old 03-28-2008, 09:09 AM
ericsenf's Avatar
ericsenf
ericsenf is offline
Default RE: what is the BEST oils for H-D
I have done a bunch of research on this and my conclusions are as follows:
Engine - AMSOil Synthetic Motorcycle Oil 20W50 - this appears to be one of the best synthetics you can find. Synthetics will withstand hotter temperatures and allow for longer use before breaking down. You also usually have a much broader viscosity range allowing for the fluid to be thinner when cold and thicker when hot than conventional oils.
Trans - AMSOil Sever Gear 75W90 or any heaver gear oil - will smooth out shifting, and be better suited for the conditions of the gears.
Primary - Harley FORMULA+ - several people have recommended that I not run synthetic due to my higher torque engine build and clutch, you need lubrication but don't want the extra slipperiness generally provided by synthetics.
Engine Break-in, initially or after engine work, use standard HD oil. You don't want your cylinders too slippery during breaking so you don't get glazing. Metal needs to wear down for everything to mate up.
I am currently in "break-in" stage, after another 100-150 miles this spring, I will switch all three holes to the above mentioned mix and then dyno... but that's another post.
Old 03-28-2008, 09:21 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
I run mobile 1... but after last season seeing how much smoother my brother and dads bike ran on amsoil I AM SOLD! putting it in all holes this season!
Old 03-28-2008, 09:35 AM
pappy43's Avatar
pappy43
pappy43 is offline
I honestly don't know whats the best...I do know that I have used Amsoil in the last three bikes that I've owned; Using 20-50 for the motor, 10-40 Primary and Sever Gear in Tranny......and I've never had an oil related problem. So in my head I think I am using the best. Of course there will be others on here that sware by what they use.
Old 03-28-2008, 01:01 PM
Cornhusker's Avatar
Cornhusker
Cornhusker is offline
ORIGINAL: RAWHIDE07
There will never be a definative answer to this question,the most thing is to use brand names and change fluids on a regular basis.
+1 Period.
Old 03-28-2008, 01:11 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
engine: Mobil1Vtwin20w50
trans: Redline SHockproof Heavy
primary: Redline MTL
Go to the oil threads and start reading and report back next year when you are done....
FWIW: Best oils IMO
Redline
Amsoil
Mobil1
Royal Purple
Spectro
HDSyn3 as a last resort.
Just use a 75w90 gear oil in your trans.
Old 03-28-2008, 01:28 PM
WildBillAce2's Avatar
WildBillAce2
WildBillAce2 is offline
I just switched from the HD Syn-3 to Amsoil in both the engine and the trans and it's great! Less noise from the trans witht the 75-90.
Old 03-28-2008, 01:32 PM
strengthin1's Avatar
strengthin1
strengthin1 is offline
ORIGINAL: FXDC Rider
AmsOil is probably hands-down the best, but there are so many great synthetics out there.
+1...the best...period!
+1 - I agree on Amsoil. I ran HD Synthetic 3and not impressed. Less noise in the tranny now too.
Old 03-28-2008, 01:36 PM
07bobber's Avatar
07bobber
07bobber is offline
I USE HEAVY WEIGHT REDLINE INPRIMARY AND ENGINE& TRANNY HAS REDLINE SHOCK PROOF
Old 03-28-2008, 01:42 PM
DougsDyna's Avatar
DougsDyna
DougsDyna is offline
[sm=outcold.gif]1001 answers is correct...............[sm=popcorn.gif]
I don'tike Syn3.
It all became so controversial I drained all the holes, and just run er dry (really got confusing)[sm=joke.gif]
DougJ
Old 03-28-2008, 03:11 PM
Punty's Avatar
Punty
Punty is offline
Please make it stop![sm=deadhorse.gif]
Quick Reply: what is the BEST oils for H-D
