Current opinions on installation of V&N Big Radius pipes on '06 Dyna
I was wondering what the current standing is on what should be done for a successful self install of the new V&N Big Radius pipes on the new closed loop Dyna '06 EFI system?
What will be needed and is it absolutely necessary to do anything except get the new download to the existing feul computer from HD and adding a high flow air filter?
Thanks, I really want to avoid getting everything done only to find the feul mix is all messed up. My understanding at this point is that you need only move the existing O2 sensor inot its slot on the new pipes and add the high flow air filter and you are in good shape. That additional tuning is not absolutely necessary right off the bat.
