Terminal Velocity Fuel Management System II
has anyone with an 06 dyna tried this yet? http://www.terrycomp.com/tv.html
If not, why? It seems like the simplest route to go compared to finding the right maps etc for PC or tuning the serts
opinions?
opinions?
RE: Terminal Velocity Fuel Management System II
The 06 Dyna EFI is a closed loop system and does not require remapping.
I am not sure what good the Velocity FMS would do unless it is tuning and I do not know if it is necessary. Running on a Dyna does not do anything for you either or so I have been told because you cannot adjust it I am trying to find the answer to that. All you apparently need to do is put the o2 sensor in the bung of the new 06 compatable pipes and the computer will dot eh remap since the system is closed. You could not remap it manually if you wanted. However you apparently do need to replace the existing air filter with a high velocity system so the engine gets enough o2 because the performance pipes will increase the dumping of air so you ahve to increase flow on the other end.
I wish a serious expert would address this. I have heard that the dealers do not want it getting out how easy the upgrades of exhsust is on the new EFI bikes because they are making an easy $500 doing pipes for customers. Or so one mechanic said in GA after posting or writting an article in a magazine.
Stucarius
02-06-2006 04:06 AM
