Warming up the Harley
Old 03-26-2008 | 08:17 PM
Biggol's Avatar
Biggol
Default RE: Warming up the Harley
I typically fire it up with the choke out, let her idle while I put on the gloves, then ease it out of the neighborhood. I have ran it after sitting idling for 5 minutes and even letting it run about 10 before easing. Doesn't change the way it feels one bit. Still have to get2 miles or so down the road before I can start pushing that choke in. I can finally put it all the way in when I hit 65mph on the interstate stretch. All gravy from there.
Old 03-26-2008 | 08:20 PM
traveler's Avatar
traveler
Your sig pic is in Oak Park!
Old 03-26-2008 | 08:28 PM
PigInaBlanket's Avatar
PigInaBlanket
I agree with starting it and riding it almost immediately but easy.
The only time I let it warm up for a minute or 2 is when I had a carb on the bike just so it wouldn't cough and die on me when pulling out in an intersection or something. With the fuel injection on my current bike I don't have to worry about that crap anymore.
Old 03-26-2008 | 08:48 PM
DougsDyna's Avatar
DougsDyna
I usually start mine up in the garage, then put the gloves and helmet on, back the bike outa the garage, get off and close the garage door, take a glove off, find my smokes and light one up, plug myself in (cold weather), ride the bike up the steep hill to the driveway, stop and remember I left something in the house, put er in nuetral and put the kickstand down, walk down the hill 100 feet or so to the house and grap the cell or whatever else I left in the house, go back up the hill and get on the bike, take off a glove and get another cigarette, light it and plug myself back in (cold weather), put er in gear and ride to the main gravel road, then pretty much idle the few thousand feet to the hardtop road.
I guess I do take at least 5 minutes warming it up.
In the Summer it's probably more like 4 minutes.
I have read a number of articles that say to put like 12 miles miles or so on the bike before getting down on it hard, but don't think I can wait that long.
I dont think it does any engine good to run it hard, without at least allowing the oil to circulate and warm up a little.
DougJ
Old 03-26-2008 | 08:54 PM
Punty's Avatar
Punty
ORIGINAL: ninetyzero
on my tc96 i just let the choke do its job, once the idle comes down to about 1000 i saddle up and go
+1
Old 03-26-2008 | 09:04 PM
sharkey's Avatar
sharkey
One of the reasons to warm up good before twisting the wick is to let all that metal between the cases and valve covers expand to operating temp. Blew a gasket on my 100hp Sporty getting it on with a motor that wasn't up to full operating temp. Waaaaaay up north here, it's normal to let a motor warm up a bit, especially since we pull directly out onto the highway; then I'll go at least 10-15 miles before I even think of opening up the throttle on my 103. Mine will idle at about 1500 with the enrichner pulled out a bit after starting, or I'll use the throttle screw to set it. I don't find the starting routine in any way annoying; just part of the ritual.....like pushing in the comp releases, or warming up your partner before you both enjoy the ride.
[IMG]local://upfiles/32069/6A3F13FFB1F044E08BA0B934A44B1EF7.jpg[/IMG]
Old 03-26-2008 | 09:09 PM
96 Wide Glide's Avatar
96 Wide Glide
ORIGINAL: ezriderpgh
Hmmm seeing how they go from 0-240 degrees in about 1 minute I would say 1 minute is plenty long enough.
Maybe your does........ but I'll tell you, my motor is nowhere near 240* after idle'ing for one minute!
Old 03-26-2008 | 10:38 PM
Gadgetech's Avatar
Gadgetech
My process: Crank it up, get suited up or whatever and take off easy. I would say I let it warm up about 2-3 minutes or so before riding.
Old 03-26-2008 | 10:48 PM
sargek's Avatar
sargek
When I'm leaving for work in the morning (at o'dark thirty), I fire up in the garage with the door shut, not that it really matters, but it holds the echo down to less than a block...it's about a two minute warm up by the time I get my gear on and roll down the driveway. When I leave from work, I let her idle for about 2 or 3 minutes then take off.
Old 03-26-2008 | 11:04 PM
voyager1's Avatar
voyager1
easy one here guys... Let that sucker warm up before you take off. next question ?
Quick Reply: Warming up the Harley
