Warming up the Harley
RE: Warming up the Harley
It'll be 38-39 degrees when I get home from work in about a half hour. I'll idle the bike for 5 or even 10 minutes before I go ride. In my mind, I'm letting the thick cold oil heat up and get circulated, allowing the viscosity (sp) to change to something a little less sludge-like.
Whether or not that's what really happens, I don't know... it's just what I think I'm doin...
I warm it up in the middle of summer too, though definitely not as long.
I let it idle for about as long as it takes to pick the bike off the stand and put it in first gear. Everyone has an opinion on this and mine won't change anybody else's nor theirs mine, but in many (many) years around engines of all kinds I've never run into one that really benefitted from running at idle speeds. Personally, I think you do the engine a lot more good getting it up to speed where the oil pump is going full pressure.
I quietly walk mine down the driveway to the curb, position it so the pipes are facing my AH neighbor's bedroom window, then light it up at 4 in the morning.
Then let it idle as long as it takes to wake em up. And twist it a few times so the injection wont load up.
I was told that the reason that you let the bike warm up is that you don't blow a lower jug gasket. I have a 98 super glide with 44,000 miles and no oil leaks at all. i let her warm up good and take it easy till everything is warm up as I let her warm up The choke is all the way in and I just give it a little gas with the thumb screw till it races a liitle now she is warmes up
