Dyno done today after 103 Baby Build
Old 03-25-2008, 02:19 PM
Cornhusker's Avatar
Cornhusker
Cornhusker is offline
Default Dyno done today after 103 Baby Build
Did a 'Baby Build' a while back on the sickle. I really wasn't after performance, I wanted a better (more traditional) HD sound. Bored cylinders out for 103c.i., Installed new SEpistons and bolt in SE-211 cams. Everything else stock. The Dyno turned out better than I anticipated. 100.54 ft lbs torque and 93.31 HP. I don't know if the Dyno image will show up or not. It's definitely not what I do best.
Well, I managed to get the image on here, even if it isn't the best.
[IMG]local://upfiles/22103/F83E2680FBC849A097F5FE4D9EEC18B7.jpg[/IMG]
Old 03-25-2008, 02:24 PM
Topspin's Avatar
Topspin
Topspin is offline
Default RE: Dyno done today after 103 Baby Build
wow... big numbers!
Old 03-25-2008, 02:59 PM
lolife's Avatar
lolife
lolife is offline
What did that cost ya?.................... . . . .are you happy......................... . . . . .. .........
Old 03-25-2008, 03:01 PM
07bobber's Avatar
07bobber
07bobber is offline
AWESOME......
Old 03-25-2008, 03:25 PM
WildBillAce2's Avatar
WildBillAce2
WildBillAce2 is offline
Try and save it as a JPG file off of your scanner. Nice numbers!
Old 03-25-2008, 03:26 PM
Cornhusker's Avatar
Cornhusker
ORIGINAL: lolife
I'm real happy! I installed some Rinehart Slip-ons before the build. It sounds great and performs better than I ever anticipated from this type of build. Cost was between $1200-1300. Closer to $1300.
Wish I could figure out how to get the Dyno chart on the site.[:@]
Old 03-25-2008, 03:48 PM
Cornhusker's Avatar
Cornhusker
ORIGINAL: WildBillAce2
That's what I wanted to do, but couldn't find the option. I'll keep trying. Thanks.
Old 03-26-2008, 10:02 PM
JayFromPa's Avatar
JayFromPa
JayFromPa is offline
Not to shabby on the numbers for the money spent.
Old 03-27-2008, 11:57 AM
strengthin1's Avatar
strengthin1
strengthin1 is offline
Wild Bill, Noticed your ride and rebuild specs. Do you mind me asking if you know what numbers you're putting up? I did similar work to my '03 so I'm just curious. There's so many different combo's out there that give different results for money spent. Your mod's seam close to my mods.My 95cibore includesS&S 510 gear driven cams, Wiseco 10:50 pistons, Rinehart staggereds, 42mm Mikuni, Forcewinder air intakeandTwin Tech ignition got me 99HP and 112Ft lbs of torque.No head work done.Great looking scooter WildBill! How do you like your Lepera seat? I just ordered the same one. Should be in Friday. Hurry up Spring!
slyedog
Engine Mechanical Topics
03-03-2015 09:19 PM
ronherman
05-25-2013 12:34 PM
Kennyboy62
09-08-2012 06:32 AM
jakeryder
07-25-2010 11:08 AM
dragonx
03-03-2009 05:29 AM
Quick Reply: Dyno done today after 103 Baby Build
