Polyurethane Vs. Rubber Riser Bushings?
Old 03-21-2008, 02:39 PM
strich's Avatar
strich
strich is offline
Default RE: Polyurethane Vs. Rubber Riser Bushings?
When I put my apes on, i had to switch over to poly. The rubber was way to unstable, even when braking at 5mph. It's nice to have that solid feel.
Old 03-21-2008, 02:43 PM
Yellotang's Avatar
Yellotang
Yellotang is offline
I heard that the poly made setting the bars straight easier.
[align=left] [/align]
Old 04-28-2011, 07:33 PM
rideamap's Avatar
rideamap
rideamap is offline
Just installed Polyurethane bushings today. Great for tall handlebars as it almost completely eliminates any play in the handlebars. I actually installed them in hopes of eliminating a crooked riser problem. Risers still pull about .08" to the right. A little better than before.
Old 04-28-2011, 07:44 PM
h2o's Avatar
h2o
h2o is offline
I put polys on this winter. I won't go back.
Old 04-28-2011, 08:43 PM
PigInaBlanket's Avatar
PigInaBlanket
PigInaBlanket is offline
I hated the mushy feel with the stock Street Bob mini apes and the stock rubber bushings. Put on poly bushings with the 14" apes and it feels better than Oprah in skin tight spandex... then again what doesn't feel better than that?
Old 05-01-2011, 06:59 PM
harley_jeff's Avatar
harley_jeff
harley_jeff is offline
I installed mine today. I recommend this mod. The bars feel much more solid, and there is no noticeable increase in vibration. In fact, the mirrors seem to shake less.
Some cautions - make sure you cover the forks and the headlight with bubblewrap or something along those lines to protect the surfaces from getting dinged by your tools. Cover the tank/instrument cluster with a bunch of towels to rest the handle bar assy on. And, be careful on the RH riser bolt. There is a ground wire and it is very easy to break the terminal off the end of the wire (guess what I have on order from H-D?).
Old 05-01-2011, 08:41 PM
ak47dennis's Avatar
ak47dennis
ak47dennis is offline
Ditto \ with the 5" risers on my WG drove me crazy! Seemed like my bars were never going the same direction as wheel.
Old 05-01-2011, 09:40 PM
harley_jeff
And another thing - I noticed that after the bolts were torqued that the new bushings changed the angle of the handle bars. I had to re-adjust the mirrors as they were pointing upwards.
Old 05-02-2011, 07:11 AM
masplumber's Avatar
masplumber
masplumber is offline
Default Poly Bushings
I just switched to poly bushings, bars a lot more solid but vibration has increased significantly. At low rpm (under 2500) I thought the mirrors were going to fly off. Above that I no longer get a shake in the bars only a buzz. I've decided to try the"vibranators" to see if they can reduce the buzz and clear up the mirrors.
Old 05-02-2011, 07:27 AM
02fx4dude's Avatar
02fx4dude
02fx4dude is offline
I swapped out my front end this spring and put in poly bushings in the process. Same general observation, more solid and slightly more vibration. I'll give it some time, if it's really a problem I might see if I can do something about it.
Jez78
02-19-2018 07:14 PM
harlot
05-23-2016 08:37 AM
jgcable
08-13-2014 11:47 AM
jimmers1817
11-28-2010 01:03 AM
twofish
03-27-2008 03:17 PM
Quick Reply: Polyurethane Vs. Rubber Riser Bushings?
