21" front wheel on 07 lowrider?
Old 03-15-2008 | 12:19 PM
Skibros2's Avatar
Skibros2
2nd Gear
Default 21" front wheel on 07 lowrider?
Anyone know if you can put a 21" wheel on the front of a 07 lowrider without many mods?? The dealer tells me I need a wide glide front end. Surely someone has a 21" on their lowrider. Any help would be great.....thanks
Old 03-15-2008 | 12:31 PM
0ut1aw's Avatar
0ut1aw
Default RE: 21" front wheel on 07 lowrider?
Thats crap
I have a 99 FXDL narrow front end (ie sportster front end) and I put a 21in spoke on mine no mods no nothing
In fact the 21 80/90 dunlop has the same amount of space between the wheel and fender. spacers all worked the same everything.....
Old 03-15-2008 | 01:36 PM
Brewtality's Avatar
Brewtality
according to hdwheels.com the 07 lowrider can accomodate a 21x3.5 wheel with a 120/70-21 tire without any modification
Old 03-15-2008 | 06:55 PM
jmpancoast's Avatar
jmpancoast
ORIGINAL: Skibros2
I have a 21" front wheel on my 06 Super Glide. It would be the same to put one on a newer Low Rider. I used the hub from my 19" spoked rim and laced a 21" rim to it. Here a pic:
Old 03-16-2008 | 09:55 PM
Skibros2's Avatar
Skibros2
2nd Gear
Thanks, your bike looks awesome
Old 03-17-2008 | 12:15 AM
Dynaflyer's Avatar
Dynaflyer
Here is a pic of mine I finished a few days ago.
I went the wideGlide way. Replaced the Tripple Clamps. Wideglide Rim.
The easiest way would be to find a Mid Glide Hub then have it laced to a 21" Rim.
If I am correct all of the 07 and 08 Hubs are 25mm OD.
In that case you would have to go with a 25mm axle and 25mm sliders if your bike has the 1" or 3/4" bearings
With your 07, get a 07 hub and Have a 21" rim lased to it. Make sure the hub is a midglide and the bearings match your axle. You will save bucks that way. Plug and play after that with a 90/90-21" tire. You won't have any fender issues due to the lower profile of the new tire.
Old 03-17-2008 | 07:23 AM
Skibros2's Avatar
Skibros2
2nd Gear
Thanks for the reply. I really like the wide glide front end alot. How much do you have into the swap? Does it effect the handling at all? Was the swap Difficult? Do you have a side view picture so I can see the added fork angle?Sorry for all the questions, but I just love the look, and it's exactly what I'm looking for........Thanks
Old 03-17-2008 | 07:35 AM
tbone52's Avatar
tbone52
ORIGINAL: Dynaflyer
.......If I am correct all of the 07 and 08 Hubs are 25mm OD.......
3/4 in. front axle - '00-'03 Dyna
3/4 in. rear axle - '00-'05 Dyna
1 in. front axle - '04-'07 Dyna (except '04-'05 FXDWG)
1 in. rear axle - '06-'07 Dyna
25mm front axle - '08 Dyna (except FXWDG and FXDF)
25mm rear axle - '08 Dyna (except FXDF)
3/4 in. front axle - '00-'05 FXDWG
Old 03-17-2008 | 11:45 AM
Dynaflyer's Avatar
Dynaflyer
The Rake is only1/2" more. I don't notice it. the Handling is much more nimble in turns and counter steering. I have not had it out on the highway yet because there is just a lot of salt left on the roads yet.
Price was roughly $800.00 and Change.
Tripple clamps $310 plus shipping from Zanotti's
Front wheel eBay $200.00
New Front tire ,tube and band $105.00
Chrome tapered spacers $50.00
New Poly Bushings for Handle bar risers. $40.00 [This is optional]
Misc hardware,Four 3/4" chrome spacers for fender, new pinch bolts. $?
Labor to have tire installed, I had to go with custom bearings due to the wheel I purchased.
Had to buy andhave bearings installed as well.
Link to more pics
https://www.hdforums.com/m_3034191/tm.htm
Old 03-17-2008 | 03:42 PM
trampsinger's Avatar
trampsinger
Yes my children, it can be done!
Bluesrider
10-12-2014 09:56 AM
trampsinger
07-10-2012 04:16 PM
strengthin1
02-08-2008 01:22 PM
Xmedic
08-01-2007 09:44 PM
Roadster_Rider
07-05-2006 09:41 PM
