round ac cover on an 88
I've got what I believe is the SE round K&N ac on the scoot now with the stock football cover. The filter element itself says " for use with TC 88 cover only" What would stop me from putting on a round 8" cover?
[IMG]local://upfiles/51712/68CCF47DD24348BFBFCA8F9CE4C6D669.jpg[/IMG]
[IMG]local://upfiles/51712/7F7B26417DBF477CB21D92AB4F1B6D77.jpg[/IMG]
RE: round ac cover on an 88
If you're talking cover 29138-91, you need PN 29591-99; it's a sponge stick-on gasket to space the a/c out so you can screw it on snug without wrecking the screw hole
[IMG]local://upfiles/32069/34E456057DAF43378E1A7F684BBB564D.jpg[/IMG]
[IMG]local://upfiles/32069/268C0D5D4CF947DAB16E7052FF7A0910.jpg[/IMG]
The reason you need to use a gasket of some sort is to keep the round cover from vibrating and cracking the center out of your element. Been there. Done that......Twice. The first time itcracked and I fixed the crack with some JB Weld. Not long after, it cracked again in a different spot. It only took about 2k miles to do it the first time. After learning that lesson, I put a couple of rubber washers on the bolt and use some 1/4" foam weather stripping on the rubber gasket on the front of the element to act as a cushion.
[IMG]local://upfiles/17633/C1C72D23C7AA40EFBE9A3D20079D3944.jpg[/IMG]
ORIGINAL: xxxflhrci
OneBlackFly
05-26-2007 09:02 AM
