New Slip ons and engine dies
I had seII's put on my 06 superglide at the stealer and i had the airfilter and the download also.. the pipes require more air and our rides are finiky... the airfuel needs to be adjusted is the reason for the download.. but nice selection on pipes... I like mine
Part of your problem may be your bike is now running too lean. Bikes come from H-D set really lean so they comply with EPA; and, the increased exhaust flow from having slipped on less restrictive mufflers can cause them to run even leaner ... you probably need to have your ECM remapped or add an aftermarket EFI module. There are quite a few to choose from, but after having read all the debate about different providers I decided to go with Dobeck Performance TFI. I believe there are several other parts mfrs who put there label on the TFI, too.
R/
Priest
R/
Priest
ORIGINAL: maverick101
Were you using 89 oct before the pipes were put on?
ORIGINAL: mudpuddle
Jeremy, first thing is to check for trouble codes.
https://www.hdforums.com/m_650106/tm.htm
mud
mud
I checked the codes an there were no codes that showed up.
I think I need to clarify something that may make a big difference. The bike idles fine when I start it up. It seems to only dies after it has been ridden and I come to a stop. The bike starts right back up without a problem, and will idle fine until I ride a little way and have to come to a stop and then if I dont keep a little gas on it, it will die.
Well, if there are no codes and the problem didn't exist before the muffler change, then I would put the stockers back on and see if the problem goes away. It would be uncommon if it does, but right now its the only way to be certain (that I can think of). If it actually does improve, then I'd just leave the stockers on until you are able go with the full blown Stage 1 (hi-flow a/c and remap) before putting the SEs (or something else, even) back on. This is me, what I would do.
