Replacing turn sigs
RE: Replacing turn sigs
ORIGINAL: strich
I just put the order in with the moco this weekend for about 2K worth of new parts.
One of them (4 actually) is blacked out turn sigs. No more chrome.
But i'm wondering when i install the turn sigs, are they plug and play
or will i need to strip and weld to replace?
should be a simple remove and replace operation.
If you need to remove the AMP fittings from the wires,
have a look here -
https://www.hdforums.com/fb.asp?m=2711998
mud
ORIGINAL: mudpuddle
strich, I haven't seen the blackparts you ordered, but,
have a look here -
mud
ORIGINAL: strich
have a look here -
mud
they're just the basic blacked out HD turn sigs. I don't have the part numbers on hand, but it's just a replacement for the shiny stuff. Thanks for the link to the tut. It seems pretty simple. I'll give it a go. I'm not sure that i've got any 16 gague wire laying around. Will a pick do for that purpose? I guess this all just takes more patience than it does anything else. I guess with replacing 4 of these, we'll see how patient i really am.
thanks for the info, i'll let you know how it turned out.
ORIGINAL: strich
strich, any skinny pick, wire, paper clip, etc. will work.
Once you get the first one it gets easier.
mud
TylerBoehm
01-19-2014 11:20 PM
ggadwa
05-02-2009 01:40 PM
