25 MPG ?! hmm..
Old 03-08-2008 | 06:09 PM
AdrianVall's Avatar
AdrianVall
Default 25 MPG ?! hmm..
Hey all,
As some of you know, I just recently switched to a PCIII from using the V&H FuelPak. Since then, my gas mileage has been extremely POOR! I'm getting 32 highway miles, and 25 in city. Now, that is just downright TERRIBLE. I'm running the AN big sucker stage 1, V&H Big Radius, and PCIII on an 06' StreetBob with a map loaded from FuelMoto.
Anyone have any suggestions, or is this just normal with changing out the exhaust process? I will be getting the bike dyno tuned within the near future, but until then, are there any other better maps I can use or what? Could someone please help a brotha out!
Cheers,
Adrian
Old 03-08-2008 | 06:16 PM
DGlide04's Avatar
DGlide04
Default RE: 25 MPG ?! hmm..
What was your mileage with the Fuelpak installed? Any special reason for going to the PCIII?
Old 03-08-2008 | 06:57 PM
jamman's Avatar
jamman
whats the problem? did you really buy your bike for fuel economy?
Old 03-08-2008 | 07:29 PM
AdrianVall's Avatar
AdrianVall
Well, compared to what I was getting before, its a huge decrease. If thats what happens with the exhaust change out, then thats fine, but I have a feeling its more then just that.
With the fuelpak, I was getting about 33-35 in city, and 45'ish highway. And I switched to the PCIII for personal prefrence, and for the ability to be able to get the bike dyno tuned. But I am very happy I made the switch, as my bike is running MUCH better since.
Old 03-08-2008 | 07:54 PM
Trotter's Avatar
Trotter
You need to goDyno the bike ..... You'll get much better than that ..... Pre loaded maps are just close... Tune it you'll see afterwards how much better it can really be...
Old 03-09-2008 | 01:49 AM
dirico1266's Avatar
dirico1266
What are your setting on the first row in your map on the FUEL table in your PC.
If you did not buy from fuelmoto chances are those fields are not setup right. But it looks like you have.
Call jamie and have him send you another map. he can help you out.
Old 03-09-2008 | 08:46 AM
BigJfxdwg's Avatar
BigJfxdwg
Maybe you are getting on it to much to enjoy the new found power.
Hey it's happened to many people.
Seriously, I would get it dynoed to dial in the PCIII a little better, it should help a lot.
Take a look at your plugs, how do they look?
Old 03-09-2008 | 08:51 AM
BLade1127's Avatar
BLade1127
You definately need to get something done. I have the same set-up, Fuel-Pak/Stage 1/except I'm running BigShot Staggerds. Last time I checked, I was averaging 47 miles to the gallon.
Old 03-09-2008 | 08:59 AM
06streetbob's Avatar
06streetbob
I have the PCIII I'm running BigShot Staggerds,K&N airfilter kit. Last time I checked I was averaging 45 miles to the gallon. 36 to low 40 mpg if I get on it alot.
Old 03-09-2008 | 09:57 AM
Whiffleboy's Avatar
Whiffleboy
With my SERT (no Dyno) I'm getting 29mpg city and low forties hwy. That's about the same as it was with the DFO.
Whiff
bambamblazer
09-11-2008 12:46 PM
06FXDCIRider
04-22-2007 11:21 PM
Bluuzplayer
11-13-2006 12:00 AM
Todd Vikan
08-05-2006 04:59 PM
Angry_Inch
07-13-2006 09:59 AM
Quick Reply: 25 MPG ?! hmm..
