tank lift
Old 03-06-2008 | 10:58 AM
stillridin42703's Avatar
stillridin42703
Default tank lift
need pics of 2 and 3 inch tanks lifts,,,,and how the fuel line was ran
Old 03-06-2008 | 11:04 AM
2007fxdc's Avatar
2007fxdc
Default RE: tank lift
ORIGINAL: stillridin42703
Here's my 2 inch jackyl lift. You don't need a new crossover with the 2" lift.
[IMG]local://upfiles/41150/D10E2D9D56E849C4BE549FCCCC3FDFC9.jpg[/IMG]
[IMG]local://upfiles/41150/95BD0AC190A144F2BD5B14D1DD1AEFEB.jpg[/IMG]
Old 03-06-2008 | 11:42 AM
Dynamite17's Avatar
Dynamite17
I have an 07 Lowrider and the 2" Jackyl lift kit was pretty easy, but there was one issue that the directions didnt address. The fuel line is no problem (although I did disconnect it, quick disconnect fitting) but the problem was the evap. line. It is connected to the frame with a plastic connector, I could not lift the tank high enough (even 2") without removing the snap connector off the frame.
My fuel guage is 1/4 - 1/8 off but the usable fuel isnt affected since the fuel line connects near the back bottom.
Sorry, I don't have a pic to post right now.
B
Old 03-06-2008 | 12:31 PM
matkiwi's Avatar
matkiwi
On the 2" I just had to replace the fuel line due to rubbing through so better to fit a new one at install.
Old 03-06-2008 | 12:45 PM
2007fxdc's Avatar
2007fxdc
ORIGINAL: Dynamite17
The evap line dynamite is talking about may vary from one bike to the next. Mine is pulled tight but I did not have to replace it. Jackyl does include a longer replacement line in the kit though should you need it.
3" lift will most likely require replacing the crossover line as well.
My fuel gauge was off before the lift and now is close to perfect with it - go figure...
Old 03-06-2008 | 01:13 PM
paisleysdaddy's Avatar
paisleysdaddy
I got a dumb question....... What's with a tank lift? I guess I haven't really noticed much of a benefit from a cosmetic or mechanical standpoint. Can anyone elaborate??? (sorry if this sounds dumb, but I won't know if I don't ask)
Old 03-06-2008 | 01:23 PM
Dynamite17's Avatar
Dynamite17
ORIGINAL: paisleysdaddy
It allows more of the engine heat to come up to your body instead of being trapped under the tank.
Old 03-06-2008 | 01:26 PM
Dynamite17's Avatar
Dynamite17
ORIGINAL: matkiwi
Are you sure it was the fuel line and not the evap tube (rubber tube going in with wire bundle on top/front of the tank)?
The fuel line is under the tank on the left side and has a quick disconnect fitting. There was no stress on that at all in my installation.
Old 03-06-2008 | 01:30 PM
matkiwi's Avatar
matkiwi
ORIGINAL: matkiwi
Doh ... I meant the crossover at the front of the tank ...
Old 03-06-2008 | 02:36 PM
2007fxdc's Avatar
2007fxdc
Two things. First, as someone pointed out, it is supposed to allow more air over the engine for better cooling. But, I venture to say the real reason most of us have it is cosmetic. It gives the bike a mild chopped look. It's one of those things people may notice and still have no idea what you did. Can't beat it for the price. For me, I liked the look and it also corrected my fuel gauge issues and put the tank at a better angle in relation to my handlebars and also allows me to read my dash mounted speedo better without having to take my eyes completely off the road. Nobody expects everyone to like or to buy one. Just like other mods, they aren't to everyone's taste.
Quick Reply: tank lift
