tank lift
RE: tank lift
I had to change both my lines, both were cut short in production I guess.
Times must have been tough that week at the factory.
Realistically, I had had a piece of fuel line laying around, and the other tube was under $1 at the hardware store.
At first the tank lift was for cosmetic reasons, but since I did my tank change, (from FXD to Lowrider) it turns out that I will be making a newtank lift,and use the top of it for my indicator lights.
Yeah, I'll post pics, I just thought of the idea last night. Gimme a few days to make the part.
[IMG]local://upfiles/39969/080D40EF51C3442EBA459C89719E6D94.jpg[/IMG]
RE: tank lift
ORIGINAL: 2007fxdc
My crossover now touches the frame and I am keeping an eye on it. But, it should be fine according to jackyl. There isn't anything rough there that should rub a hole.
ORIGINAL: matkiwi
I meant the crossover at the front of the tank ...
RE: tank lift
ORIGINAL: 2007fxdc
ORIGINAL: matkiwi
Doh ... I meant the crossover at the front of the tank ...
I ordered this braided fuel line to replace my crossover from JP
LINK
RE: tank lift
Let's also not forget that a 2" tank life makes it a simple matter to clean the top of the cylinder heads - your hand will fit under the tank with the tank lift in place. This is not possible to do without a tank lift or without lifting up the tank.
Regarding the crossover hose touching the frame - what I did was take an old piece of fuel line, about 4" or so, cut it open, and fit it over the crossover hose where it touches the frame. Problem solved forever for about $.15.
RE: tank lift
i installed a Jackyl 2" lift very quickly and easly. But i did have to slot the rear tank mount some due toupper triple tree bolt hitting tank when getting off bike. I also stole the nut off the rear tank bolt so that both front nuts matched. And also had to replace the evap line.
[IMG]local://upfiles/44795/4AB0F12A062F4415A8E5432146674713.jpg[/IMG]
RE: tank lift
I don't recommend the 3" tank lift at all.....................[8D]
It looks too nice, makes it easier to refuel, fuel gauge is more visible, fits the seat nicer to the tank, creates less turbulence than the stock setup, makes it easier to clean the rocker covers, and may even allow the engine to run cooler, makes you feel like you are sitting more down in the frame........... this can't be a useful mod
DougJ
DougJ
RE: tank lift
ORIGINAL: BoomSoon
OK indulge me here please. I am a first time bike owner(FXDB Black Denim), had for a year. Lovin every minute of it. So what is the real need and want to get a tank lift kit? Look? Airflow? Or what? Thanks BTY- incredible site. More information than you could pay for.
