chrome dash panel
RE: chrome dash panel
ORIGINAL: dyna rider
In my opinion the best thing you can do is order one from Harley to fit a Screaming Eagle Dyna. It comes in chrome, for $125.00, and has the ignition switch mod everyones been doing. I ordered one for my Bob but it hasn't come in yet.
Not even close on that SE Dyna dash. The SE dash has the key switch on it-Bob doesn't, alsoSE has 1/2" larger speedo and wider bolt pattern for mounting. It is the same dash that is on the Streetglide Custom, Wideglide, and Fat Bob. There are 4 dash models for the Dyna line. The one that I mentioned that the 3bike modelsshare, the Street Bob dash, Low Rider dash(has a tach), and the regular Streetglide. The dash on the Streetglide can only be used on that tank because it has the fuel cap and guage in it and speedo on the bars. All the other dash consoles are interchangeable because it's the same tank on those bikes. You can install the chrome dash from those bikes on the Street Bob but you will need to purchase the bigger speedo and move your ignition switch to the dash position.
