tires
RE: tires
ORIGINAL: hddave2
well thats got me thinking ..i thought a 180 tire would fit on stock sg wheel..i know they make the wide tire kit 180/60/17 se for the 06 dyna's..its suppost to be a stock replacment tire jut a little wider..
The 180 SE from Harley is made special for them to fit the 06 Dyna's.
A stock 180 is designed for a 5" rim. You can get it on a 4.5 but it will squeeze the profile. Gonna change the handling.
I put the 180SE on mine and got less than 6000 miles. It is a soft tire.
I know there is a lot of guys that have put them on and have no problems. Well not me.
RE: tires
oh gee!! Same concept in the 4x4 world, most of Super Swamper tires tend to be larger than actual size. other brands goes under than actual. i dont know why.
guys -Dunlop just got new line of tire out, which is called RoadSmart, i read about it and its suppose to be very good tire. they have 160-200s. looks similar to avons. Check out the actual sizes of each tire sizeto see if they are bigger than the mez 170s.
Falcon195
10-08-2013 11:32 AM
