rear wheel
rear wheel
I got an o6 street bob, and i was thinking of putting a duece rear wheel. I like a solid rear wheel with a the spoke front, since the deuce has the same size tire and axle i think. it should just be a question of spaceing and if the rotor and sproket will match up. I would put a 180 tire on it .. any thoughts????
RE: rear wheel
The Bob can hold up to a 180 with the existing fender usinf spacers for cables. Anything larger will require a new fender. If you go to a 21" front low profile and 180 rear the apparent visula change will give you the duce look if you had kept the larger lower diameter front tire.
