Hello From Tampa Florida Area...Street Bob Handle Bar Swap Question
Old 03-03-2008, 09:05 AM
UNCLE PAT's Avatar
UNCLE PAT
UNCLE PAT is offline
Default Hello From Tampa Florida Area...Street Bob Handle Bar Swap Question
I get to ride ALL year long here in FLA. I picked up an 08 Street Bob and I love it. I am looking to change out the ape handle bars to the straight type of bars....can anybody put me in the right direction as far as risers....swappable parts....anything that may need to change other than the obvious??
Thanks
Pat
Old 03-03-2008, 09:33 AM
JayFromPa's Avatar
JayFromPa
JayFromPa is offline
Default RE: Hello From Tampa Florida Area...Street Bob Handle Bar Swap Question
I assume your looking to put drag bars on it. If so, you could try WildOne drags with intergrated risers. I think they look better versus using straight bars and risers with a hnadlebar clamp. If you want to have them at roughly the same height as your mini apes you won't have to be concerned with changing cables out. They also look great if you take the time to internally wire them as well. There is plenty of slack in the stock harness to do this, all it takes is a little bit of time in the garage.
Here's a link to the WildOne site. http://www.wild1inc.com/
Old 03-03-2008, 10:34 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
you could make your own... they are real simple to make and then you can use your stock handlebar clamps... we make our own risers all the time... here is a set we made for my brothers sporty...
Old 03-03-2008, 11:18 AM
UNCLE PAT's Avatar
UNCLE PAT
JRK...those are awesome....I want that type of look.......talk to me....send me a PM.
Old 03-03-2008, 11:49 AM
UNCLE PAT's Avatar
UNCLE PAT
can you make up a set for me bro???
Old 03-03-2008, 12:36 PM
Brewtality's Avatar
Brewtality
Brewtality is offline
one thing you need to know, if you don't already:
the 08 Street Bobs have the risers integrated into the top of the triple trees. you can't use after market risers with the stock triple tree set up.
Old 03-03-2008, 01:03 PM
UNCLE PAT's Avatar
UNCLE PAT
I'm learning that now O.B.....I talked with wild1 and they recommend a W0503 for the Bob. But then I would need to make a top single clamp vs. the two clamps that the Bob has now. I think that should be an easy make.....any other concerns?? here is a pic of what wild1 said would look sweet and work as long as I make the top single clamp...
Old 03-03-2008, 06:01 PM
UNCLE PAT's Avatar
UNCLE PAT
I just went up to my local Harley dealer and bought a set of bras just like those shown....it took 2 hours to put them on...what a difference...I like the look better now.!! thanks guys....if anybody is interested in the part number...just lmk.
Old 03-03-2008, 06:08 PM
NOTORIOUS1's Avatar
NOTORIOUS1
NOTORIOUS1 is offline
i went with the stock nighttrain setup off a sloptail. see sig below
Old 03-04-2008, 04:17 PM
UNCLE PAT's Avatar
UNCLE PAT
very nice notorious....well I took some pics last night...here they are. I like the lower bars...Thoughts??
Quick Reply: Hello From Tampa Florida Area...Street Bob Handle Bar Swap Question
