Rear wheel alignment.
Hey guys I bought a 07 lowrider last august and it is making a little squeak out of the rear wheel. It sounds like the wheel may be out of aligment or something because it is coming from the belt side of the rear wheel. Could the wheel be out of alignment and cause this squeaking? I had the stealership look at it when they did the 1000 mile service and they told me that it was just making the noise because the bike was new and that it would go away before to long, I dont beleive this at all. What do you guys think? How do you go about aligning the belt and making sure everything is good. I am sure that this is a repost but since the search feature is down I could not use it, any help would be greatly appreciated. Thanks in advance
Jeremy
Jeremy
RE: Rear wheel alignment.
The rear belt tension. The correct way to do it is with a belt tension gauge. If you do not have one, you can do it by feel for a TEMPORARY fix. When close to properly adjust tension, you should be able to pinch the belt with your fingers and rotate the belt about 45 degrees.
After you have the tension, do the wheel alignment. There is a factory drilled hole on each side of the swing-arma few inches in front of the axle nut. Using something like a piece of stiff wire, bend it in a U shape so one tip hits the center of the axle nut, the other hits the factory drilled hole. Do this on the belt side first. Shape the wire (in the U shape) so you can use it as a gauge for the other side. On the two sides, the distance between the rear axle nut and the factory drilled hole should be about the same, no more than 1/16" difference. After the wheel is aligned, check you belt tension again. Re-tighten and realign if necessary.
Final,buy or borrow a belt tension gauge.
Check out the tech section of the forum. Info for rear wheel alignment and belt tension can be found there.
I checked the rear alignment like stated above and everything checked out fine. What could be making the sqeaking noise. It almost sounds like a brake rotor because it only sqeaks at a certatin point in the rotation of the rear wheel. Is it possible that the belt rotor is bent?
Several other things to check:
As mentioned, get a belt tension gauge. Improper belt tension is a common cause of the churp.
Check the bolts which hold the pulley on the wheel and make sure they are tight.
A dirty belt canmake is noisy. Clean with mild detergent and a toothbrush.
Check the lower debris deflector and make sure it isn't hitting the belt and that its bolts are tight.
I guess its possible, but not likely your pulley is bent.
