Fiberglass as a do-it-yourself baffle
What do you folks think about usingfiberglass waddinglike the kind found in some automotive mufflers as a baffle for bike pipes. There may be some motorcycle pipes that offer fiberglass but I don't know. Anyway, seems easy to me it would be easy to throw in there and shouldn't be to hard to retain it in place. I'm just wondering what it would be like for performance.
Dirt bikes have replaceable muffler packing. Here's the stuff. http://www.motosport.com/offroad/pro...&cat0=DIRT
TGWP - I made a whole new baffle for my HD 2:1 for my '04 Dyna using mild steel diamond mesh. I welded two long pieces and cut a round end cap and started filling it in with smaller cut pieces. It was LOUD. But sounded good. To quiet it down I used Stainless Steel wire mesh pot scrubbers instead of glass. I did this out of need - not want. I left the stock baffle in my buds camper when in Daytona and he left with it - across the country - So I had to make a baffle or lose my hearing. A couple of days open header was fine but...
Yes it is tough to keep the glass in place - there is a lot of force out the pipe.
I now have a Screaming Eagle 2:1 and I took the baffle out and cut the stock glass down to one wrap. I used SS wire (3-4) to keep it in place. The SE is pretty loud stock and sounds good, but I may make something that makes the "megaphone" sound. Meaning the stock baffle is a small diameter pipe and I don't think you get the big sound.
Good luck - let me know if you want me to post a pic or two. dd
Mr.Softy
06-09-2014 09:07 AM
tmitchellof PG
10-28-2007 10:12 AM
