Polished stock fork sliders
Old 02-25-2008 | 01:22 PM
Dynaflyer's Avatar
Dynaflyer
Default Polished stock fork sliders
Doing a wideGlide mod with a 21" wheel and while waiting for parts decided to strip and polish the front stock
fork sliders.
Used a spray stripper to remove the clear coat. Sprayed let sit for an hour thenused a green pad to gently remove the Factory clear coat. Wet sanded with 800 grit, then used a Mothers Mini powerball in high speed drill with Mothers PowerMetal, Cleaned, then went over with Mothers Mag & Aluminum polish.
Not a Good as Chrome but Much better then before.
Old 02-25-2008 | 01:35 PM
kk6pg's Avatar
kk6pg
Default RE: Polished stock fork sliders
Looks really good
Are you going to put a clear coat over them so you wont have to do it again?
Old 02-25-2008 | 01:49 PM
billyboy890's Avatar
billyboy890
doing the same to mine(had a bad day yesterday see my post in off topic)hope mine come out as good
Old 02-25-2008 | 01:58 PM
Dynaflyer's Avatar
Dynaflyer
ORIGINAL: kk6pg
Looks really good
Thanks!
Not sure what route to go......
Thought of a wax to protect or Clear it and No worries. How do youthink would the wax hold up?
Old 02-25-2008 | 02:13 PM
xxxflhrci's Avatar
xxxflhrci
Looks good.
I would not try to clear them. It often turns cloudy and is prone to peel. I polished the forks and most of the aluminum on my Ironhead over 10 years ago. About all I do to maintain the shine it rub it with a little Mother's a time or two a year.
Old 02-25-2008 | 02:17 PM
kk6pg's Avatar
kk6pg
If it were me, I'd clear coat them again.
With all the road garbage out there, you'll be hitting them with the buffer once a month just to keep them looking good. If you have the time on your hands, thats one thing. If you'd rather spend that time in the saddle, it's another.
Old 02-25-2008 | 02:18 PM
Dynaflyer's Avatar
Dynaflyer
ORIGINAL: xxxflhrci
Looks good.
Thanks for the info, I thought it was just me when I polished a set of rims on my truck and then cleared them, **** they clouded up! Kinda pissed me off after putting all that effort into polishing em.
Think I gonna just wax them and consider it a done deal.
Old 02-25-2008 | 02:20 PM
Dawg Rider's Avatar
Dawg Rider
I like polished better (except for the upkeep part).
Old 02-25-2008 | 02:38 PM
JRK5892's Avatar
JRK5892
what kind of spray stripper did you use?
Old 02-25-2008 | 05:04 PM
DGlide04's Avatar
DGlide04
ORIGINAL: JRK5892
+1 on the spray stripper. How fine did you go on the sanding? The highest grit I can get locally is 1800 wet or dry.
Quick Reply: Polished stock fork sliders
