Polished stock fork sliders
RE: Polished stock fork sliders
First, you did a damn fine job on your lowers Flyer. Welcome to the fork polishers club!
There's a thread around here somewhere describing how to polish the lowers, meanwhile, here's the pics I have from when I did mine:
And then I decided they would look better black:
Here's the stuff on the bike:
DGlide04 Date 2/25/2008 7:16:21 PM Hey Rude, where do you pickup aircraft paint stripper?
fxdwgcanuck Date 2/25/2008 7:26:30 PM i agree the black looks better and less upkeep
Here's the link to Tommays' polishing thread I mentioned earlier:
https://www.hdforums.com/m_625460/tm.htm
ORIGINAL: RudeDog
True, but the shine in a well polished aluminum part is incredible.
Tommay did some nice work and that's where I got the idea.
ORIGINAL: JRK5892
what kind of spray stripper did you use?
Went to wallyworld as a last resort and picked up some spray Citri-Strip paint and varnish stripper. I let it sit about an hour then took a green scotchbright type pad and GENTLY removed the crud. A few areas It just wouldn't cut it, so used 800 grit.
ORIGINAL: DGlide04
+1 on the spray stripper. How fine did you go on the sanding? The highest grit I can get locally is 1800 wet or dry.
ORIGINAL: JRK5892
Glide, Went with 800 grit, then took the powerball with Mothers to it and that was all it took. I had an old carpet I laid down and heldthe sliderwith my foot and buffed em up. A little messy but didin't want to wussy foot around to much.
