front fork boot
RE: front fork boot
Mine are the Daystar Series 408 boots. They're actually for a dirtbike, so they're about twice as long as they need to be - but they are the correct diameter for the 49mm forks on the '07 and '08 Dynas. They were real easy to cut down.
http://www.mrcycles.com/eshopprod_ca...FORK_BOOTS.htm
Other people are using boots for a 1970 BSA or Triumph, from a guy on eBay. Apparently, these fit as-is, with no cutting:
http://cgi.ebay.com/ebaymotors/Rubbe...spagenameZWDVW
RE: front fork boot
Thanks for this information. I have been trying to find some rubberfork boots that will fit for some time. One question though... When installing these rubber boots do you remove the dust cover that snaps onto the top of the lower leg, or does the rubber boot slide over it?
RE: front fork boot
For the 39mm forks on mine I used the boots for a Kawolski W650; I took off the chrome dust seal covers and use a light smear of contact cement or grip cement on the boots before putting them in place...have a Nightster black fork brace coming from Superbrace; it has a boss on it for the boots to go over.
[IMG]local://upfiles/32069/0A31644608E44BB0AC53E618ECE95FF4.jpg[/IMG]
RE: front fork boot
ORIGINAL: lonewatie
mine are the BSA boots. As you can see from my pic, I need to resolve the issue of the boot riding up as the tubes compress and extend - anyone have any ideas for a fix to that?
[IMG]local://upfiles/48997/B9F906BD46A34CBC84A1A93710E51961.jpg[/IMG]
RE: front fork boot
everyone I really appreaciate all this imput. I ordered my daystars today and well was wondering how did you all install them? I know this was all posted in an earlier post but I can not for the life of me remember how everyone installed them. i have my front rim off and fender, can I just then run them up the lower forks with some kind of like soap water combo and attach them as stated above with wire tires or ? Again, I appreciate all the help.
