painting lowers
Old 02-21-2008 | 04:09 PM
SPECIAL ED's Avatar
SPECIAL ED
Default RE: painting lowers
I've done this before with other bikes as long as you get a good quality high heat paint you can spray it in the frame and the paint will cure as you run it.Plasticoat is about the best I've used but Rustoleum will work.Just make sure it's rated at 1200 degree or better, I know you motor won't get that hot but the other stuff they sell at kragen that's only rated at 350 is crap.Make sure the motor is spotless, clean it with something that will cut grease like rubbing alchohol,acetone or brake and parts cleaner and make sure you get all of that off or dry before you start.
Rubline
03-14-2018 03:08 PM
tguild
Powdercoat & Paint
08-01-2013 03:53 PM
MyBigBlue
11-02-2012 10:41 AM
maddog359
Powdercoat & Paint
05-30-2011 10:46 PM
phopnick
04-04-2008 11:22 AM
Quick Reply: painting lowers
