Replacing grips on my FXD
RE: Replacing grips on my FXD
You'll need to glue the left hand one on and try and remove the exsisting sleeve from your stock (i assume) throtle grip. I can't say for sure how succesful you'll be in that the first thing I changed on my bike was the grips and I tossed the old ones in the trash can.
You'll have to loosen the switch housings, I thinkI rememberthe left one is on top of the original grip so it will have to be opened to remove the original grip, I installed the same grips and both of my switch housings moved a little bit further up on the bar., the left one will be easy to remove I used a strap wrench and it twisted off.
The right one I had to cut off and peel it off ()you wont have to open the switch housing, I also had to scrape it to get it clean enough for the new grips. it took awhile but was simple and straight forward.
Be careful when you glue the right one on that you dont get it glued to the bar.
