I want to add a tach to my 07 Superglide
Old 02-17-2008, 01:22 AM
ioncat14's Avatar
ioncat14
ioncat14 is offline
6th Gear
Default I want to add a tach to my 07 Superglide
Hello everyone,
I was wondering if any 07 Superglide owners have added a tach? I went to the dealer yesterday and they told me that there isn't a tach kit for the 06 or the 07. Would a 05 tach kit work?
Old 02-17-2008, 04:19 AM
mfuchs2004's Avatar
mfuchs2004
mfuchs2004 is offline
Default RE: I want to add a tach to my 07 Superglide
I looked too. I'm told that from '06 on, HD began using USB instead of more traditional cables so the '05 tach should be out. Just one wire to run everything from the ECM to all the gauges, signals, etc. I can't find any HD ref to a tach for the FXD yet.
You can go aftermarket. I'm told that pin 3 on the ECM is the spot to hook it up, but I haven't verified that. Better check the manual.
Old 02-17-2008, 05:33 AM
jmpancoast's Avatar
jmpancoast
jmpancoast is offline
I added an aftermarket digital tach/speedo to my 06 FXDI. The tach was not that big of a deal to hook up.
I ran a wire from the tach unit to the ECM. I disassembled the ECM plug, put a terminal on the new tach wire, placed it in slot #3, and plugged it in.
I realize this may not be the unit you are looking at, but the tach hook-up should be similar. Hopefully, this will open up more options for you.
[IMG]local://upfiles/23085/199EC1B7AE8348CDB3C8F902CAE99287.jpg[/IMG]
Old 02-17-2008, 07:42 AM
txtec's Avatar
txtec
txtec is offline
the 05 tachs work .you have to wire to the #3 ecm pin like jmpancoast said.
Old 02-17-2008, 08:28 AM
JayFromPa's Avatar
JayFromPa
JayFromPa is offline
HD Part # 67224-04.
Around 236.00 from Zanottis. Includes everything needed to add a tach.
Old 02-17-2008, 09:02 AM
RAWHIDE07's Avatar
RAWHIDE07
RAWHIDE07 is offline
Received 39,939 Likes on 13,496 Posts
HD is always adding new products to their website,so I am going to wait awhile.However speedwayinstruments.com has a small,neat digital tach that is cool.You can see a video of it on youtube.
Old 02-17-2008, 09:32 AM
risdo's Avatar
risdo
risdo is offline
Here's mine. It's a Drag Specialties tach that I bought from Dennis Kirk. It came with a clamp for the handlebars, but I didn't use it: Ijust mounted it to the handlebar risers. The angle is perfect: 5500 rpm, which is the redline on the 96 inch motor, points straight up.
Old 02-17-2008, 09:37 AM
txtec's Avatar
txtec
txtec is offline
did you have to buy a adapter for the drag speac.tach or did it read right without one??
Old 02-17-2008, 09:43 AM
risdo's Avatar
risdo
risdo is offline
Here are the parts: # H20028 Tach Adapter; # 407395 Inductive RPM Sensor... I'm not sure if those were the manufacturer numbers or dennis Kirk's numbers, but I think they both show up in a search.
The tach adapter was required because the '07 96-incher has single-fire ignition, and the tach will only show half the RPM's without it.
Old 02-17-2008, 09:49 AM
txtec's Avatar
txtec
txtec is offline
thanks for #s i dont like the honda 750 look of the h.d. tach kit.
Quick Reply: I want to add a tach to my 07 Superglide
