O2 Sensor Inline Enrichment Device
#42
RE: O2 Sensor Inline Enrichment Device
ORIGINAL: Kricke
flube the pipe up real good, then saw of the intruding crossover end (mayby intruding not is a english word ; ).
Quite common mod on the baggers Y-pipe to gain 2-4 Hp and and get a cooler engine due to less restrictive header..
You speak better english than most Americans I know.
And yes, intruding is the perfect word for the obstruction. Makes you want to go kill it.....
#43
He he yes if you have a "curved" hole saw you can do the rear pipe,, naa just pulling your leg here...
If you look on the crossover fittings on the rear headerthere is another type of mount welded and as far it wasin my "old" wide glide -07 pipe there weren't any obstruction (learn't a new wordfrom KK6Pg) to worryabout.
#45
Installed my IED's today and took a ride,can't say I actually FEEL any real difference;smoother? maybe, and the engine seemed not as hot when Ipulled into the garage and shut down.
They are easy to put in, I had never looked at the front caddy so it took me some time to see how that came apart, the rear was a snap. I'll get a laser thermometer on it soon and see how the temps compare with what they are finding on the tech forum.
Thanks Kricke,for you help.
#46
I've been following this thread with interest. My new Fat Bob doesn't arrive for another month, so I can't test these IED's myself yet, but in looking at the 08 Harley parts catolog I see that Harley offers 2 different oil caps with oil temp gauges on them (one is analog, the other is digital). Since these IED's were made by Nightrider to address the high engine temps associated with 06 and newer 96" motors I'm thinking a good check might be to invest in one of these oil caps with a temp gauge, and check the before and after oil temps with the IED's installed.
Ok, now under the "seemed like a good idea at the time" catagory, I just looked at the catalog again and it doesn't look like Harley offers a cap that fits the newer Dyna's.
#47
OK, now last weekend I tooka 300mi round trip up the Columbia Gorge and I can say the IED's are an improvementat cruising speed, engine about 30 degres cooler ( i got a laser thermo) andmy gas mileage dropped fromm 44 to 42 mph.
Performance improves subtle but noticeable;
So I would recomend these. Bear in mind, I have the stg 1 download (opened up the rev limiter and more fuel on the high end($150.00) and now $70.00 into these IEDs, so, for $230.00 I have a fuel mgmt system that works for me, yet it is not adjustable or anything like the fuelpacks, PCIII, etc.But I'm happy with the way I run now.
#49
I posted this in the Tech Forum but copied it here since it was relevant and you could see my personal results:
Things I have not noticed but doesn't mean they aren't/didn't happen:
- louder exhaust
- more performance
- temperature change....well maybe, but is it me just wishing it? Hell I don't know but I hope it is cooler.
Things I have noticed:
- low rpm surge is MUCH less if non-existent but I really went low to make it happen yet very noticeable change.
- spark plugs look much better. Not as white - can definitely see a color difference from before and I'm sure it would be better if I cleaned them more before the run.
- one thing that surprised me that I did notice and never really thought about is while moving at a low/midrange rpm in any of the gears the 'casual missing', you know, like you get sometimes when there is not really enough fuel in the mix for the spark to create an ignition which feels like a random dead spot, was also gone and made me really take notice.
So, just by these simple findings the IED's are doing something. Is it the best....no but for the cost the results are very impressive. I would say this is for those who don't want to spend money on a fuel manager and help their bike run at a healthier state be it only .5 richer in air/fuel ratio.
For the record, I have the SE Air Cleaner, a Stage 1 Download, and Rush 1.75 slip-ons.
- louder exhaust
- more performance
#50
