O2 Sensor Inline Enrichment Device
#31
#32
RE: O2 Sensor Inline Enrichment Device
ORIGINAL: Dynabob07
My 07 street bob just got upgraded to samson big guns3 exhaust and SE1 air filter and a power commander...
My engine light comes on after the bike warms up....
I am now thinking maybe to get this instead of dyno tuning the PC....for the $325
#33
Dynabob hmmm if the engine light comes on after warm up I think the O2 sensors are disconnected or the blocks from PC3 arent in place or have bad connection. check thefault code andpostit here and I'll help you find the answer...
And on your question if to replace PC3 for the enricherners i would say no,in my opinion get a god dyno setup and your be fine or if you are up for a little testing get the enricherners and plug them in after the initial PC3 tune so you use the closed loop feature again.
I can't help you with a dyno run (I live in Sweden so...) But surley some of the guys/girls here should have the right connection to a good localtuner...
//K
//K
#34
#35
OK, I'll see if my bad english can explain....
Make sure run/stop switch is set to run
Press and hold "trip reset button"
Turn ignition on
then you should be in diag. mode and you should see PSSPT (not 100% sure on the letter combination on -07)in your speedometer
press trip again and the first letter start flashing and if you have any fault there should be visable (go thru all letters with same procedure)
write down the code you findthen press and holduntil a verification that you cleared the fault code...
I have aflow chart thati can mail in case of total confusion ; )
Turn ignition on
#36
I had an SE Race Fueler on my 06 bob. It ran much betterbut no matter what I did I kept gettingtwo codes, rear cylinder rich and rear cylinder lean. I had the two dealers check it out and they said everything was fine and that this was common on the Race Fueler. I think it's the nature of the beast on the O2 equipped bikes. I ditched the Race Fueler and went with the SERT. No more codes and it never pops.
I still have the Race Fueler if someone is interested in taking it off my hands. PM me and make an offer. The Race Fueler is good for someone low on cash (which I was at when I bought it). But I saved up a year and went with the SERT and am completely happy.
Sorry for the shameless plug.
#37
#38
So, for a stock intake and only a set of slip-on pipes ('07 WG with Krome works 3" HPs) will this device do anything for decel pop? Also, it would be interesting to see a dyno comparison before and after, with just pipes and stock air and fuel management. I'm a cheap bastard, just wanna know if it will do anything I can hear or feel. Also, any change in MPG.
Tim
Tim
#39
#40
fastfxrs
There arent any major hp/Tq changes in closed loop going from +14.7-1 to 14.2-1, but you will probably feel the engine going smoother and not as hot as before (it was this purpose these devices were built for).
You will burn more fuel (you are richen the mixture so....)
Small tip when using stock headers: is that the crossover tube is pushed quite far in the front pipe.
So I took a hole saw (as big i could get in the pipe) lube the pipe up real good, then saw of the intruding crossover end(mayby intruding not isa english word ; ).
Quite common mod on the baggers Y-pipe to gain 2-4 Hp and and get a cooler engine due to less restrictive header..
