Oil Filter Problem
Old 02-02-2008, 06:24 PM
chappy's Avatar
chappy
chappy is offline
Default RE: Oil Filter Problem
For next time around use a K&N Oil Filter;
Has a nice nut to remove it when your done.
Plus, I think they are superior to H-D.
chappy
Old 02-02-2008, 06:55 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,838 Likes on 2,548 Posts
not to insult anyones intelligence but i didn't see anyone mention to make sure the new filter's gasket gets wiped with a coat of fresh oil and tightened hand tight. sounds like the old one went on dry, if seen that in automobiles. good luck
Old 02-02-2008, 06:57 PM
seniorsuperglideE8
somebody moved my "f" and "V" key. I've seen the same thing on cars when the filter goes on dry.
Old 02-02-2008, 07:16 PM
Pondslime's Avatar
Pondslime
Pondslime is offline
E8
OP was asking how to remove a tight filter.
Hand tight doest work on my 05 dyna it comes loose and leaks while rideing. The first time was fun, second nearly ended bad.
My experance only
Cheers
Old 02-02-2008, 07:30 PM
seniorsuperglideE8
understood the question real well, just trying to avoid the situation again. Thru my experience of tightening the oil filter 1/2 to 3/4 of a turn after the filter contacts the base I never had one leak on me but I suppose when one does real bad it could ruin your day. (02 FXD and 05 FXDLI). g' day and ride safe down there. kinda odd isn't it getting a message from yesterday or one from tomorrow?
Old 02-02-2008, 07:33 PM
JJHarley's Avatar
JJHarley
JJHarley is offline
6th Gear
Do what Chappy said . Use K&N filters. Better filtering than a Harley filter plus easy on easy off all for about a dollar more
Old 02-02-2008, 07:36 PM
06dynablack's Avatar
06dynablack
06dynablack is offline
dont change the filter no more problems with loosening anyways
Old 02-02-2008, 08:15 PM
BlueShift's Avatar
BlueShift
BlueShift is offline
ORIGINAL: jmpancoast
Made by Drag Specialties. Cost $10.00. Its one piece so not much to break. Works with a 3/8" drive ratchet. Has a cutout to protect Crank Positioning Sensor. Preserve your pride and pick one up.
That's the one I have. Last time I changed the oil I picked my bike up with a sky hook.
Old 02-02-2008, 11:50 PM
dynasty's Avatar
dynasty
dynasty is offline
yea, gota get the one piece. always, always get the right tool for the job. the wrench pays for itself first time you use it - pretty good purchase if you ask me.
eviltwin415
09-25-2017 11:55 PM
balfbaby
05-12-2014 09:00 PM
kpb46
02-19-2014 08:19 PM
HFS
Oil Archive (no new posts)
03-12-2011 10:08 PM
Mr. Lucky
04-04-2010 07:40 AM
Quick Reply: Oil Filter Problem
