Fix the front end clunk and save $5 in the process
Old 02-01-2008 | 01:24 PM
07bobber's Avatar
07bobber
Default RE: Fix the front end clunk and save $5 in the process
I CANT SAY WHETHER OR NOT IVE EVEN EXPERIENCED THE CLUNK YET. I GOT MY BIKE 1/07. AM I INCLUDED IN THIS PROBLEM?
Old 02-01-2008 | 03:00 PM
towboattrash34's Avatar
towboattrash34
hmmmmm first i heard of this.....i'll have to check it out...
Old 02-01-2008 | 03:04 PM
Yellotang's Avatar
Yellotang
Thanx for the info.
[align=left] [/align]
Old 02-01-2008 | 04:18 PM
williamfrog's Avatar
williamfrog
Order stem washer (45727-08) at HotmetalHD in Pittsburgh today $2.95 .
Frog
Old 02-01-2008 | 04:23 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I ordered my $1.70 washer. Does anyone know what size socket it takes for that steering head nut?
Old 02-25-2008 | 04:45 PM
davidwideglide06's Avatar
davidwideglide06
Installed washer this weekend per instructions and no more clunk! In fact when I bent old washer down, the steering nut was only hand tight.
David
Old 02-25-2008 | 06:20 PM
bronk's Avatar
bronk
As always,,,,,,,come here and get answers. Go to the dealer and get the reacharound![:@]
Old 02-25-2008 | 08:43 PM
DynaDan's Avatar
DynaDan
ORIGINAL: 07bobber
You'll know if you have the problem. On my bike it is pretty obvious. If I go over a rough spot or bump while using the from brakes I get a clunk. I would probably change it anyway. I need to break down and order the new washer. I assume you need jack the bike up and check the fall away after you tighten the nut.
Old 02-26-2008 | 12:00 PM
davidwideglide06
Instructions said to check fallaway after torque of nut. I do not have a lift, so didn't check but the front end feels okay for now. Atleast no more clunk.
Old 02-27-2008 | 02:25 PM
DynaDan's Avatar
DynaDan
Here's one for ya. I go into the dealer today to pick up a part and I go back to the service department to ask about this service bulletin, just to see what they will tell me. He tells me bring my bike in and they will fix it. Well, as I was talking to him I told him I was probably going to get the part and fix it myself since it is just a washer and all you have to do is replace it and torque it to spec. Then he says "There's no torque spec on that nut, just on the washer. You just get it good and tight and then check the fall away." WHAT?!
Funny, I'm sitting here looking at my '06 Dyna Service manual on page 2-65 under the steering head assembly and it states "tighten fork stem nut to 45-55 ft-lbs" and Muddyape says the new instructions say tighten to 70-80 ft-lbs.
Thanks, but I'll do the work myself.
It's interesting the new instructions have you torque the nut almost twice as tight.
Quick Reply: Fix the front end clunk and save $5 in the process
