O2 sensor eliminator question
Old 01-24-2008, 11:16 AM
Uquackmeup's Avatar
Uquackmeup
Uquackmeup is offline
Default RE: O2 sensor eliminator question
The stock o2 sensors are extremely narrow band and try to keep the afr at 14.6:1. Some of the aftermarket fuel management systems come with replacement wide band o2 sensors to get around this. Some, like the Doebeck/Techlusion unit use a bypass with a resister that gets around the o2 sensors limiting factor. I've been running one of these for the last 10k miles and my bike runs great. http://www.techlusion.com/
Old 01-24-2008, 11:25 AM
hmmr's Avatar
hmmr
hmmr is offline
ORIGINAL: Arcane
I can certainly be wrong but I am under the impression that the current Delphi system on the Harleys is not a true closed loop system, I think that it is a partial closed loop system that goes closed loop only under certain conditions. The rest of the time it operates in open loop.
Arcane
i was under the impression that as long as the system reads the exhaust prior to it mixing with outside air, never introducing outside readings into the algo, it is closed-loop.
Old 01-24-2008, 11:51 AM
dlstanf2's Avatar
dlstanf2
dlstanf2 is offline
The O2 sensor eliminators have a known resistor value in them to simulate a certain value, basically putting the ECM into a know state The platinum wire temperature compensator in the air intake tract of a fuel injection system, as in a closed loop system, gives feedback to the ECM to adjust fuel/air ratios within a specified range. The PCIII basically bypasses this feedback loop and adjust the fuel/air ration (maps) separately, and the maps tune the fuel/air mixture according to rpm/throttle position.
The ThunderMax system, replaces the stock ECM, maintains the O2 sensors, and has multiple wires (vs. the HD 2-wire) thereby being able to control the A/F ratio over a much broader range. Even with this system, it still has to have a basic map installed, (taking into account any engine/exhaust changes you have made).
There are several threads on the forum that go into great detail about a FI systems. Worth the read.
I know that I plan to get a T-Max system down the road and replace my PCIII.
Old 01-24-2008, 12:05 PM
buellrider76's Avatar
buellrider76
buellrider76 is offline
All right, at the risk of opening a giant can of worms, I see that several people have mentioned other mapping systems. What is the best system out there and for what application, stock, slightly modified, highly modified. Never had EFI before so I'm a little new to this area.
Old 01-24-2008, 12:23 PM
Uquackmeup's Avatar
Uquackmeup
Here's a link to a site dedicated to the EFI topic:
http://www.*****************/forums/fo...play.php?f=109
You'll have to insert v-twinforum .com where the asterics are in the link.
Old 01-24-2008, 12:26 PM
buellrider76
try that link again...
got it. it's v-twin
Old 01-24-2008, 12:29 PM
arnold's Avatar
arnold
arnold is offline
It looks like that websiter is filtered out on by intent (mods).
If Im right dont look for trying it again to work, I think thats the vforum or some such-competition must be tough
"You'l have to insert v_twinforum .com where the asterics are in the link as the link is blocked"
OIC said the blind man
He hee hee, not to sure I like a forum that wants to charge you to use the good stuff, volenteer support sure, but come on.
Membership Type: Free Member Premium Member Lifetime MemberPrice: Free 1 Year
US $15* Lifetime
US $40
Tomahawk309
04-30-2019 06:29 AM
thundergod
08-20-2008 07:19 PM
trevd
04-08-2008 09:12 AM
JFjeld
09-12-2007 10:16 AM
Ash
05-12-2006 12:27 AM
Quick Reply: O2 sensor eliminator question
