New HD Black custom wheels
#41
RE: New HD Black custom wheels
https://www.hdforums.com/m_3320388/tm.htm this guys got em if the thumbnails work for you... lol.
#43
Okay, just got it back, been 3 weeks without the bike and it felt good to finally get her back. \\; Attached are some pics. \\; The wheel looks great, now my only problem is that I really want the back one now (looks a little funny, but it will have to wait cause I am not parting with her again till the end of the season). \\;
Anyway, as for the construction, well made, it lives up to the Harley standard, even though it was inexpensive. \\; The spokes are pretty thick, between a 1/4 and a 1/2 inch, very smooth finish, no rough spots that I could tell. \\; I just got back, got my son to bed and took the pictures a little late so sorry if they are dark, but they give you the idea. \\;
As for Part numbers, you'll love this one. \\; It took them 3 part orders for 1 wheels. \\; First the wheel, then the rotor part number was in the instructions, then a separate order for the bolts to attach the rotor. \\; Here are all the numbers.
Wheel: 44657-08
Front Disc: 44553-06A
Bolts and Washers: 3762M, 6966M
That should cover it. Feel free to ask me any questions.
Pics go here, since this thing would not let me upload
http://picasaweb.google.com/Walsh.BrianG/06StreetBob
Wheel: 44657-08
#48
Thanks Bdog, I was hoping that was not the case. If I decide to buy these wheels I didn't want to have to buy any more than I have to. You did use the "stock" tires though correct ? One more "dumb" question. When using the "stock" tires, do you still use the tube or do they become tubeless ? One guy was telling me that the OEM tires are both tube and tubeless depending on what kind of rim you put them on. BTW, how much did the stealers charge you for the install ? Thanks again.
Marcusg
Marcusg
#49
I think in total just for the wheel it cost, was about 600 (just for the front, I still have to get the rear done), if I remember correctly is was 1.25 hours of labor on top of the parts. \\; I had some other work done so my bill was higher but not sure. \\;
Yes, stock tires worked, but I could not tell you if they are tubeless now, never thought to ask.
#50
Marcus, you can use the stock tires. And yes, they're tubeless when going to a mag type wheel. As for the rotor question, it IS a stock Dyna rotor on front, BUT it's the stock rotor from the factory mags like on superglides/lowrider. Ask your dealer if they have any take off rotors from an 06/07 superglide front mag. You can usually pick em up cheap that way.
The rear tire on my bro's bike is a Screamin'Eagle 180, but you can still use the stock 160. The front is a 19" and the rear is still 17". Same as stock dimensions.
D
D
