New HD Black custom wheels
RE: New HD Black custom wheels
ORIGINAL: 6165hd
What is everyones opinon on cast rims vs. spoke rims....?? Ive heard casted rims can be a bit harder in the bumps and alittle pushy with cross winds?? Where the spoke rims give flex with pot holes & junk, and wind has more area to go through.
Food for thought/
Thanks,
Joe Shmoe[X(]
Food for thought/
Thanks,
Joe Shmoe[X(]
ORIGINAL: 06 harley
do they make it in chrome?---BRIAN
http://www.performancemachine.com/thankyou.html
Torque:
Contrast Cut Torque:
Anyone out there get these yet. \\; I had my dealership get me one for the front (after the front spoke got bent). \\; Anyway when they went to put them on, turns out the rotor with the spokes doesn't work with these, now the dealership is trying to find a rotor that works with it. \\; Any help would be appreciated.
bdog22
what is the exact issue with the rotor does it not bolt up or align with the brake caliper...you could easily make a spacer
also http://www.hardcoreproduct.com/ \\;has very well priced wheels...980 for a set to your door. \\; Ask for Steve and let him know Luke with the 06 Street Bob refered you.
SkyRider - Thank you for the info, but don't know what the issue is, but I don't think it has to do with the brake caliber, since the Harley catalog specifically calls it out as a problem with the one for the spoke wheels. \\; It is at the \\;dealership now, so not a 100% sure other then that it just doesn't fit together. \\; If they don't have an answer I will look into these you pointed out, since they look reasonable (Do you have a set on yours? Any pics?)
I'm running the 5 spoke (or however many it is) \\;cast dyna wheel powder coated black on my st.bob now but would prefer this new wheel over the ones I have now.....I went this way because I did not want to spend the cash (in 06) \\;for the real trick spoke wheels \\;that some on the forum are now running......wonder how much cheaper these new wheels \\;will be thru Zanotti's?????
I'm pretty neutral on cast vs. spoke but, I can tell you that if your on a long trip and get a flat you can plug the tire right along side the road and then all you need is some air or a pump....if your runnin spokes you've got a problem.
