Bike wouldn't start!
Old 01-24-2008 | 06:00 AM
DougsDyna's Avatar
DougsDyna
Default RE: Bike wouldn't start!
ORIGINAL: jmpancoast
Doug. has SCAAT showed up on your caller ID this week?
No, and it's hard to work on the bike without tools............. mine are in hiding
Hows your Bob running?
DougJ
Old 01-24-2008 | 06:02 AM
jmpancoast's Avatar
jmpancoast
LMAO
Old 01-24-2008 | 07:26 AM
b5mac's Avatar
b5mac
Trotter, are the batteries that you have the no maintenance type and how much do you want for one? I checked the voltage at the accessories plug and got 0 volts. That might be from a blown fuse in the accessories line but I've never had anything hooked up to it so I don't know. I'm going to pull the battery today after I get home from work. Once I pull the battery, I'll check the voltage again.
Old 01-24-2008 | 07:32 AM
Trotter's Avatar
Trotter
There the standard HD no maintenance replacement Battery's... I'll call Shawn and see what we pay for them when he gets to the shop 10:00..
Old 01-24-2008 | 03:53 PM
b5mac's Avatar
b5mac
Well, I took the battery out and found that the positive terminal cable was very loose. I've got the battery on charge now and I'm hoping it will take a charge. Funny thing, though, my accessory connection has a blown fuse but I've never hooked anything up to it. I can't figure out how that could have happened. I have to take a closer look at the wires to see if it has chafed on something and shorted out. I can't think of any other way the fuse could have blown.
Old 01-24-2008 | 06:28 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: b5mac
Mark, I owe you an apology.............. didn't realize that was your bike in the parking lot, and used the accessory outlet to make a pot of 12VDC coffee............. that thing really needs a 20 amp fuse. I was real cold that morning, too!!
DougJ (not home)
Old 01-24-2008 | 06:56 PM
fxdwgcanuck's Avatar
fxdwgcanuck
the battery will proably be fine was it is charged the loose terminal would prevent the battery from charging look for that short unless is it possible some condensation got in that plug
Old 01-24-2008 | 10:02 PM
SUPER01's Avatar
SUPER01
ORIGINAL: b5mac
Hey I said to check that in post #4. [sm=confused06.gif]
Damn Harleys and the vibrations.
If that's all it is, should be good.
Old 01-25-2008 | 01:24 PM
b5mac's Avatar
b5mac
You were right Super01, the battery wasn't dead at all. I put it back in and made sure the terminals were tight and the bike started right up. Good call!
Old 01-25-2008 | 02:44 PM
Trotter's Avatar
Trotter
I think Doug was right...... ( Snappy ? )
Quick Reply: Bike wouldn't start!
