POWER COMMANDER ENGINE LIGHT!!!
Just finally Installed power commander EX so with my O2 Sensors.....
Ive got the Samson Big guns 3......sound great....
have the high flow cleaner....
At idle its OK ...but when I get on it the light pops up.....
On the website.....they have an exact match for a program......
Do I still need to have it dynoed and reprogrammed.....???
RE: POWER COMMANDER ENGINE LIGHT!!!
I just installed mine today as well. I get some popping but I sure can feel the power.
I read about the engine light staying on somewhere.
Maybe one of the connectors came lose. Maybe I can find the article.
Where in the heck did you find the O2 sensor (the front one by the header pipes) I can't find it anywhere. I must be blind.
Actullay you are using your sensors.
So I am riding with one on and one off.
i had a sporty before the dyna. Once u installed ur new pipes, it throws off the air ratiosn fuel mixtures off balance. then theecu in ur bike becomes confused since u put new pipes n the rest other stuff. thats is the reason why ur engine comes on.So with powercommander, dyno is required. In order to fix it, u will have to get it dyno'd to adjust map ofthe air/fuel ratios. but, since urpipes have sensors init nshouldnt be problem without the power commander, u should be able to run fine. if uwant to run with power commander, get it dyno'd.
Chris
Chris
ORIGINAL: dirico1266
If its the plug you couldn't find, remove the voltage regulator. The plug isattached tothe plastic casing behind the regulator.
[sm=WTFsgign.gif]
ORIGINAL: 06chrisFTW
Chris
Chris
Chris
Chris
Naz
