I need some help with front turn signals
RE: I need some help with front turn signals
ORIGINAL: Travlinman314
Now I've got a silly question kind of concerning lilrooster's not wanting to solder.
I also relocated front signals with on the first week I had the bike to the HD Fugly ones.
At that time, I did cut the wires and just crimped the wires together with electrical connectors and taped them up.
Rode for a couple of weeks that way, till I found an alternative to the Fugly kit.
I then did a home made tank lift, and homemade relocation kit, then I finally soldered the wires.
This being said, I honestly and probably would never have soldered the wires toghther if it weren't for reading it in this forum.
What would, or could have happened if I would have just left them crimped and taped?
Just curious....
Just curious....
Got the very same situation... what I've found is two choices.. remove tank and work wire harness area and connectors ... or...disconnect batt, and/or main fuse, cut wires, reroute wires under steering neck, solder back together andheat shrink tube them then tie wrap in place. Finallygot a heat gun for shrink tubing.. old method of using cig lighter seemed alittledangerous that close to the gas tank... LOL R/ Ed H
[IMG]local://upfiles/44748/E5D3423120154211AEC99E92FD803DDC.jpg[/IMG]
RandyDowdy
19
08-25-2010 10:10 AM
